Warped front rotors - Victory Forums - Victory Motorcycle Forum
post #1 of 16 (permalink) Old 08-04-2012, 10:04 PM Thread Starter
bfp
bfp's Avatar
Default Warped front rotors
Changed my front tire today, and now my front rotors are warped. Don't understand how that happened. Anybody got any ideas. They are so bad it'll hardly roll. What happened?
2010 cross roads Custom
2015 Ness Magnum
2016 Magnum X1 Custom
2013 Vision Custom
bfp is offline
post #2 of 16 (permalink) Old 08-05-2012, 12:03 AM
Maybe when you installed the caliper back onto the rotor possibly one of the pads possibly was not setting in the caliper correctly. It would then possibly rub constantly because it would not set back into the caliper correctly.Just an idea.
Speedblue is offline
post #3 of 16 (permalink) Old 08-05-2012, 12:11 AM Thread Starter
bfp
bfp's Avatar
Speedblue, I am puzzled, the left side inside of the caliper is dragging on the rotor! I put a washer between the caliper, and the fork, and it will roll now. Something happened. No washers or shims on the floor. I don't get it. It looks like I could use some pads.
2015 Ness Magnum
2013 Vision Custom
bfp is offline
post #4 of 16 (permalink) Old 08-05-2012, 04:59 AM
saddlebag's Avatar
Brake pads always drag a little. There is nothing that forces them away from the rotor when you let off the brake. Maybe one of the pistons in the left side is just stuck.
You can pull the wheel and pry the pads apart manually. You can then pop off the pads and put some grease on the pistons. Sounds like you need to put new pads on it anyway.
Afterwards, make sure you squeeze the brake lever enough until the brake feel comes back before you head out on a test ride.
2011 Cross Roads
saddlebag is offline
post #5 of 16 (permalink) Old 08-05-2012, 09:04 AM Thread Starter
bfp
bfp's Avatar
Saddle, after longer inspection the rotor isn't warped at all, the caliper was dragging on the rotor. I shimmed it in .025 that mostly fixed it, but that doesn't explain why this happened. I had no shims, or spacers in there before. Why does it need it now? Do the pistons on the inside move too?
2015 Ness Magnum
2013 Vision Custom
bfp is offline
post #6 of 16 (permalink) Old 08-05-2012, 09:45 AM
saddlebag's Avatar
When you press the brake, the pistons squeeze the pads against the rotors. When you remove pressure, they have no pressure to cause braking, but they just kind of sit there and they will always drag a little. Occasionally, you need to grease those pistons up a little to keep them moving smoothly. Just make sure you don't get any on the brake pads.
I don't understand what it is that you shimmed? Did you put something behind the pad? If so, that would press it in closer to the rotors, no?
2011 Cross Roads
post #7 of 16 (permalink) Old 08-05-2012, 09:57 AM Thread Starter
bfp
bfp's Avatar
I had to shim the caliper inward away from the fork, to get the caliper from dragging on the rotor, not the pads, the caliper was dragging, hard, could barely roll the wheel
2015 Ness Magnum
2013 Vision Custom
bfp is offline
post #8 of 16 (permalink) Old 08-05-2012, 10:15 AM
Saddlebag is exactly correct. This is not as uncommon as you might think. Pull the pads, pump out the pistons just a little, not enough for them to come out completely, spray and clean with brake cleaner, maybe use some HIGH TEMP grease but only a very thin layer, and press the pistons back in. Put everything else back together or install your new pads, pump up the brake till you get resistance, and let us know if this worked for you.
post #9 of 16 (permalink) Old 08-05-2012, 10:24 AM Thread Starter
bfp
bfp's Avatar
Bob, I'm not talking about the pads dragging, I'm talking I shimmed the caliper in , now .087 to get the caliper away from the rotor it wasn't inboard far enough with the pads thin, it was grinding on the rotor. Literally metal transfer onto the caliper! I fixed it by shimming, going to get pads in a half hour or so.
2015 Ness Magnum
2013 Vision Custom
bfp is offline
post #10 of 16 (permalink) Old 08-05-2012, 10:44 AM
sixshooter_45's Avatar
Wink
Not enough information, but it sounds as though something went wrong with your re-assembly.
If you didn't have this problem prior to changing the front tire then I would retrace my installation steps.
sixshooter_45 is offline
