Smelling Gas - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 05-03-2015, 09:20 PM Thread Starter
New Member
Ironhead's Avatar
Default Smelling Gas
I have noticed that my fuel mileage has seemed to be going down lately. Today we took the bike out for the 2nd time this year and smelled gas on start up and slow speeds. There was no gas smell when I went into the shop to get it out. We road about 20 miles to eat and I didn't smell any gas when we parked. We were at the restaurant about 45 minutes and when we got going through the city streets I told my wife that i smelled gas. She said she did too. I stopped, checked the gas cap to see if it was lose or I was even thinking I might have left it somewhere when I filled up. I did not stop to get gas on this little trip to town, so It wasn't spilled gas from a fill up. But we only smelled it at slow speeds. We are headed to the Smoky's in two weeks and I need to get this issue resolved. Hoping for some help on here and hoping for an easy fix. If not I will call the dealer and take there. Any help would be appreciated.
Ironhead is offline
post #2 of 9 (permalink) Old 05-03-2015, 09:30 PM
Ghost_Rider's Avatar
I'm not sure if the vision has a vent tube or not, but if it does try taking a look at it and make sure it's not kinked or crushed anywhere
2003 V92C
Wrapped RPW Slash pipes
K&N air filter
Stebel Nautilus
Viking saddlebags
16" apes
Ghost_Rider is offline
post #3 of 9 (permalink) Old 05-04-2015, 01:16 AM
My wifes 14 XR always smelled of gas from just after it was new.
Real faint. Then it got stronger. The fuel rail was leaking.
Here is a picture of the assembly:
http://www.ebay.com/itm/Polaris-Vict...c478d6&vxp=mtr
The rail is 3 metal pieces, one in the middle that plugs into the fuel fitting on the hose from the fuel tank and 1 that bolts on to each head that the injectors seat into. These 3 sections are connected by two hoses which seem to be just glued on to them, could be vulcanized.
When the smell got worse I pulled the cheese wedge on the right side, the timing cover side. The center section of the rail, where it was bonded to the hose which connects to the rear injector section of the rail was dripping gas onto the motor. 1 drip about ever 10 -15 seconds. It had come unbonded and started to leak.
Might want to take a look. You could have a leak like we did.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #4 of 9 (permalink) Old 05-04-2015, 03:14 AM
king4wd's Avatar
I had a similar issue. I smelled gas when it had been parked for a few hours or overnight, but it ran fine. Very gradually the smell increased and one day in the garage, my wife spotted what looked like a few drops of water. It was gas. The old fuel line had started to crack and split just under the hose clamp at the bottom of the tank. A quick trip to Autozone and $4 later a new fuel line stopped the leak and the gas smell.
2012 Kingpin
05 Kingpin 50th anniversary edition- Totalled
Adelanto, CA
king4wd is offline
post #5 of 9 (permalink) Old 05-04-2015, 08:59 AM
DillPickle311's Avatar
2004 Vegas needed TB cleaning. I finally got around to it. Took tank off, cleaned it up. Put it back together. Hit starter and before it cranked I noticed gas leaking. I thought I did not tighten clamps tight enough. Took the tank off. Checked and tightened. Put the tank on, cranked and everything looked good. Rode a couple of blocked and it smelled gas and noticed it leaking like crazy. Fuel line was definitely the culprit but this was all a major pain in the butt!
All I can say it that if you guys get a strong gas smell, don't mess around, go ahead and change out the fuel line.
DillPickle311 is offline
post #6 of 9 (permalink) Old 05-04-2015, 11:01 AM
Ironhead
take the gas cap off and look at the bung flange. See if its bent from pump nozzle. Should be flat and some what smooth all the way around.
You could have a bad cap thats not sealing. Look at the rubber gasket and see if there is a mark or look out of place. Vic wants $50 bucks for there cap or NAPA has one for $6.49 p/n 7031220. For my I bet its the cap.
http://www.napaonline.com/Catalog/Re...Dp%3d3%26N%3d0
post #7 of 9 (permalink) Old 05-04-2015, 11:07 AM Thread Starter
New Member
Ironhead's Avatar
Thanks for all the help. And for what it is worth. My Kaspersky virus protection has blocked the Trojan Virus on this forum three times today. Everyone should check out the computer really good and see if they have been compromised. Someone on here has a virus.
Ironhead is offline
post #8 of 9 (permalink) Old 05-04-2015, 11:12 AM
It's not 'someone on here'. Chances are, it's one or more of the ads.
post #9 of 9 (permalink) Old 05-04-2015, 06:59 PM
gibson's Avatar
Seamonkey browser and AD blocker period...... that will help you out..
2012 Fireball Jackpot
gibson is offline
