Pure Polaris spray bomb painting advice - Victory Forums - Victory Motorcycle Forum
post #1 of 55 (permalink) Old 05-06-2015, 08:57 AM Thread Starter
LILMAGS500's Avatar
Default Pure Polaris spray bomb painting advice
Hey men , I bought a can of Turbo Silver and a can of Flat Clear in 10oz spray bombs to paint my inner fairing / dash . The instructions make no note of any primer or adhesion promoter . I am familiar with spraying paint but any advice from someone who had done this would be great , I guess I need a good enamel primer to begin with . Also , when I'm done with the base color how long should I let it set up before laying down the flat clear . The instructions are quit vague . Any help advice , greatly appreciated , I need this project to come out good . Obviously , I am painting black plastic . Thanks .
LILMAGS500 is offline
post #2 of 55 (permalink) Old 05-06-2015, 10:06 AM
SilvrT's Avatar
Most important thing you can do is clean the surface with an oil/grease cleaner. I generally use regular paint thinner (not lacquer thinner) from any hardware or paint store. I've been painting for many years and this has always worked well. Make sure you allow sufficient time for the paint thinner to dry off.
To prep the surface for adhesion, use a scuffing pad also found in paint stores. Use the least coarse one. No need to scrub hard, just give it a good scuffing. Then clean with the paint thinner followed by a tac cloth.
Spray 2-3 coats of color, waiting appx 10-15 min between each coat. Allow final coat appx 1/2 hr before applying the clear. Tac rag it before applying the clear.
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #3 of 55 (permalink) Old 05-06-2015, 10:16 AM Thread Starter
LILMAGS500's Avatar
Silvr , what about a primer ?
post #4 of 55 (permalink) Old 05-06-2015, 10:24 AM
DillPickle311's Avatar
Seems the prep work he described should take care of that. The several layers applied will do fine.
DillPickle311 is offline
post #5 of 55 (permalink) Old 05-06-2015, 10:26 AM Thread Starter
LILMAGS500's Avatar
OkieDokie , be the fist time I painted anything without a base layer .
post #6 of 55 (permalink) Old 05-06-2015, 10:39 AM
Pheonix's Avatar
If you're painting over chrome plated plastic, like on the cheese wedges, you'll need self etching primer. For what you described, the above advise should work great.
2011 Kingpin - Scarlett
Stage I Pipes with Thunder Monsters & NO Catcons
Ness Laydown Plate Holder with Custom Dynamics LED Plate Frame
Custom Ness Engine Covers
V92C Floorboards with NON-LOW Mounts
Ness Ram-Air
PC-V
Lloydz Timing Wheel
Dyno Tuned by 804 Motor Sports
97.26 HP / 110.42 # for now...
Pheonix is offline
post #7 of 55 (permalink) Old 05-06-2015, 11:50 AM
SilvrT's Avatar
Nothing says you can't but in this case, not necessary.
Regarding self-etching primer, as mentioned, you'd use that on chrome or smooth bare metal, aluminum, etc
Other than that, generally speaking 2 kinds of primer are used ... primer-surfacer (sandable) and primer-sealer.
Surfacer is used to hide imperfections. You sand it down with 400-600 grit.
Sealer is used as the last primer before color to ensure no bleeding occurs and that any sanding lines don't show.
2013 RED XCT
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
HID High & Low
Victory Apes
SilvrT is offline
post #8 of 55 (permalink) Old 05-06-2015, 11:51 AM Thread Starter
LILMAGS500's Avatar
Thank you guys , I will go primer-less
post #9 of 55 (permalink) Old 05-06-2015, 12:14 PM
use wet sandpaper its black in color and use 2000 grit. Use a bowl of warm water with about 4 good drops of dish soap. Dish soaps makes sandpaper last longer and doesn't let paint stick to paper. When your done wash part and dry with air or clean towel no paper or fuzzy towel.
Not knowing what paint your using primary parts let dry while your at work. Now your first pass of paint should look like freckles. You don't want to put on a solid coating of paint. Now after ten min spray more paint try to cover a little more of the surface. Once you have the hole part covered with paint let it over night dry.
Next day look at the painted part and if you see dust bumps in paint wet sand the paint as above but very light scuffing. Now spray your clear on let it sit about ten min between coats.
Keep shaking the the spray boom
youtube might have some good tips
I can go paint stuff and it's a lot easier then try to tell someone how to
post #10 of 55 (permalink) Old 05-06-2015, 12:17 PM
Mags
do not paint on a humid day. Paint will take forever to dry
use gray primer. Black primer will take more paint to cover the black
