LED rear signals as well fromt - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 05-06-2015, 10:54 PM Thread Starter
Default LED rear signals as well fromt
were should I buy them from . MBD , e bay , which doctors any input would be great .....
Sheman is offline
post #2 of 15 (permalink) Old 05-07-2015, 04:46 AM
BlueVegas's Avatar
The eBay stuff is garbage check out these:
http://www.hightechspeed.com
Have them on my Vegas and just put a set on my buddies Hammer. Mike at High Tech is a great guy
BlueVegas is offline
post #3 of 15 (permalink) Old 05-07-2015, 05:07 AM
BP6666VR's Avatar
That is nice looking stuff mate
Cross Country Tour 2014 [B]
BP6666VR is offline
post #4 of 15 (permalink) Old 05-07-2015, 07:14 AM
blueracer17's Avatar
Their prices don't look too bad either. I saw Made in USA and figured they would be very expensive, but they aren't. Too bad I already have Kuryakyn turn signals up front.
2004 Kingpin
Mustang Seat, Progressive 465 shock, RPW Thor Exhaust, VFC III, S&S Intake, Ness Fly bars, Kuryakyn ISO Grips and throttle boss, Kuryakyn Silver Bullets, Ness laydown plate bracket, Barnett braided clutch cable....
blueracer17 is offline
post #5 of 15 (permalink) Old 05-07-2015, 12:11 PM
Alberta Vegas's Avatar
Check out custom dynamics at http://www.customdynamics.com. They make some nice LED products.
2014 Vegas 8 Ball
Memphis shades batwing fairing
Hacker Rippers
AMS
K and N Air Filter
Alberta Vegas is offline
post #6 of 15 (permalink) Old 05-13-2015, 06:34 AM
SMTCapeCod's Avatar
Default and for a *little* tech.....
Did your install require resistors?
2006 Vingpin, Inverted forks, Progressive rear shock, Stage 1 slip-on kit, S+S intake, grips and pegs, tach and rack, corbin saddle, night dragons. KMC reflashed/retuned to 100HP/104 TQ, good'nuff.
2014 BMW 650i Xdrive
2005 Grand Cherokee Ltd 5.7L Hemi, Konis, SRT swaybars, BB
1986 Porsche 928S, slightly enhanced.
SMTCapeCod is offline
post #7 of 15 (permalink) Old 05-13-2015, 07:33 AM
FYI, If you are running front Bulbs and read LED's you need 20ohm 10 watt resistors. If you are running LED's front and rear you need 10 ohm 20 watt resistors.
Zero Cool is offline
post #8 of 15 (permalink) Old 05-13-2015, 09:20 AM
I have LEDs up front and stock in the rear of my KP and installed this adjustable flasher. It works great. Plug and play.
https://tstindustries.com/LED-Flasher-Relay-Gen2.html
2004 Kingpin
post #9 of 15 (permalink) Old 05-13-2015, 08:57 PM
ChiTownVegas's Avatar
Check with the MFG before going in and soldering resistors in. Most non-fleabay signals have them built in already. Mine went in without any mods
2012 Vegas 8 Ball
LLoydz VM1 drop in cams
LLoydz Adjustable Timing Wheel
LLoydz 1/4 turn throttle ring
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
Pirelli Night Dragon rubber
ChiTownVegas is offline
post #10 of 15 (permalink) Old 05-14-2015, 04:50 AM
DirtyDan's Avatar
Not ALL ebay stuff is garbage. Just pay attention to what and who you're buying from.
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
