need help.... - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 05-07-2015, 12:26 PM Thread Starter
Default need help....
My bike has been at dealer for several months now with no solutions..started out with a pre spring clean up and routine oil change,found a fuel fitting at top of pump leaking removed pump tightened fitting replaced filter while in there put back together would not start re checked everything same result checked to see if bike was getting fire and it was not..sent it to the shop all relays fuses and TPS and CPS checked good replaced computer still nothing am waiting on new chip for computer..,all grounds checked good.,, any other suggestions would be greatly appreciated
backroadexpress is offline
post #2 of 14 (permalink) Old 05-07-2015, 01:05 PM
You forgot to post the model and year of your bike
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #3 of 14 (permalink) Old 05-07-2015, 01:21 PM
DillPickle311's Avatar
Problem:
sent it to the shop
Solution:
Take it to right shop...
DillPickle311 is offline
post #4 of 14 (permalink) Old 05-07-2015, 01:42 PM
never heard of a dealer putting in a chip.
I don't think your telling us all or your leaving info out.
Is there spark
are you sure the pump is putting out 50psi.
Are the spark plugs wet or dry. If there dry your not getting fuel.
post #5 of 14 (permalink) Old 05-07-2015, 04:33 PM Thread Starter
Its a 1999 V92C... Yes fuel pump working properly.... No spark... Bike was running literally minutes prior to finding fuel leak..all the above mentioned componets check out fine with ohm meter except computer(ECU) it was slightly liwer on ohms than svc manual stated so it has been replaced chip from stock ECU was put in and still no spark..new chip ordered waiting for it to arrive
post #6 of 14 (permalink) Old 05-08-2015, 03:45 PM
ByteN2it's Avatar
ECM's rarely fail and they aren't an inexpensive part as I'm sure your finding out. Sounds like your guy has the service manual so there's not a lot I can add other than stupid obvious things like making sure the kill switch is functioning & in the run position (don't laugh I've seen it before) I would suspect the coil/connection could be the culprit. Most of my 99's issues have been failed sensors & not all showed an error code. I did replace the metal cased ECM with a newer model plastic cased one that seems to have eliminated a heat induced stalling issue I was experiencing. I've also had weird things like the speedo going goofy that were solved by disconnecting the battery for a while & everything comes back up working correctly. These bikes have a lot of personality
ByteN2it is offline
post #7 of 14 (permalink) Old 05-08-2015, 05:56 PM Thread Starter
Shop has my svc manual coils checked good as well ground strap removed cleaned and replaced plug wires replaced... Getting fire from stator but between there and plugs spark is lost.. The only thing that did not check out according to svc manual was ECM. So i bought a new one $799 shop put it on and took chip from stock ECM and put it in new one.. Still no fire...so i ordered the new chip $115 however no one has been able to confirm if this chip that supposedly controls air fuel mixture and blah blah blah will prevent igniition from firing... Only a "well maybe" if air and fuel aint right the ECM may keep it from firing as a protection mechanism
post #8 of 14 (permalink) Old 05-08-2015, 06:13 PM
Call or write Kevinx at Southern motorworx. If any one will know he will
(352) 215-3253
http://southernmotorworx.com/
post #9 of 14 (permalink) Old 05-08-2015, 06:17 PM Thread Starter
Thank you.. I will give it a shot
post #10 of 14 (permalink) Old 05-09-2015, 02:23 PM
RoteBaron's Avatar
You may have already said but did you check the resistance/continuity of the plug wire(s)? If no spark is getting from the stator to the plug it "could" be a wire issue especially if they've never been changed......Maybe the expert can help also. I'll keep looking around.
Good luck
Long may you ride!
RB
2013 Vision Sunset Red
Lloydz Timing wheel @ 3deg (Soon to go)
Victory High Flow Air Filter
Soon to tune with Maximus
2017 Highball - Suede Nuclear Sunset Orange
Xbow exhaust, High flow air filter, Lame stage 1 update (MEH)
RoteBaron is offline
