Power interruption - Victory Forums - Victory Motorcycle Forum
post #1 of 3 (permalink) Old 05-11-2015, 07:31 AM Thread Starter
slickvic's Avatar
Default Power interruption
While performing a routine hard acceleration run My bike stumbled at around 4500 rpm in 2nd gear. It happened twice in a row immediately as if some one shut off the kill switch. I got off the throttle and rode it for a few miles with no more incidence. Got out on the open highway and decided to get on it again and no problems. pulled clean to 5800 in 4 gears.
Any thoughts? Circuit breaker? Moisture?
slickvic is offline
post #2 of 3 (permalink) Old 05-11-2015, 12:51 PM
toejam's Avatar
Check and tighten battery terminals. If that fails to cure the problem, replace the breaker located just off the positive terminal with something like this:
Or this:
http://www.napaonline.com/Catalog/Ca...116_0361112149
2013 Anti-Freeze Green XC
Vance & Hines Slip On's
BadBoy Horn, PCV
Gustafsson +4 Windscreen
Picasso Nano PN2.350D Amp
HMD520 Gorilla Bagger Bars
2010 XC 116 Big Bore - Gone
2006 Hammer - Gone
toejam is offline
post #3 of 3 (permalink) Old 05-11-2015, 10:16 PM Thread Starter
slickvic's Avatar
http://www.amazon.com/Bussmann-BP-CB.../dp/B004AH4PDW
Or this:
Got one ready to go. Thanks for the reply.
slickvic is offline
