Speed sensor pickup? - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 05-13-2015, 07:52 PM Thread Starter
Savorino's Avatar
Default Speed sensor pickup?
What does the speed sensor pick-up to measure speed, the teeth on the width of the sprocket? Or is there something on the inside of the sprocket that triggers the sensor?
Having an intermittent speedometer issue, new updated sensor installed, battery and regulator wires cleaned.
Kinda wished I'd have pulled the belt and cleaned the front sprocket area. Maybe there is some grease or rubber interfering.
I plan on cleaning the key switch connections and continuing to check wires. May have to go back to to belt-sprocket if that fails to do it.
It is a 2003 V92C 10k, new battery, updated speedometer W/green turn signals.
ARG!
'03 V92C Stage-I
Savorino is offline
post #2 of 11 (permalink) Old 05-13-2015, 08:50 PM
ChiTownVegas's Avatar
Is it dropping to zero? Is it flying up? How long does the intermittent issue last? I assume the rest of the unit (digital readout etc) is working ok?
2012 Vegas 8 Ball
LLoydz VM1 drop in cams
LLoydz Adjustable Timing Wheel
LLoydz 1/4 turn throttle ring
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
Pirelli Night Dragon rubber
ChiTownVegas is offline
post #3 of 11 (permalink) Old 05-14-2015, 12:33 PM
wonder if you have the right speed sensor
post #4 of 11 (permalink) Old 05-14-2015, 08:20 PM Thread Starter
Savorino's Avatar
ChiTownVegas
Went to the gas station for a fill up/spring test drive, took city streets there about 5 miles 35mph - 55mph. Then upon entering the freeway on the back trip (4.5miles) noticed the speedo at 0mph still when entering at about 55mph, came back up eventually after not quite a mile.
visionjhonny
It was ordered for my bike so would expect the right one but I will try to find the original bag/receipt. good idea!
anyone have help on the original question about what part of the front pulley triggers the sensor.
'03 V92C Stage-I
Savorino is offline
post #5 of 11 (permalink) Old 05-14-2015, 10:12 PM
Originally Posted by Savorino View Post
ChiTownVegas
visionjhonny
I cannot find that information even in the service manual. That being said, it doesn't sound at all like a bad sensor or however it reads that. If it were a magnet, it would be constant or very erratic if it were say, dirty. If it was somehow counting the teeth on the sprocket, again, it would be either all or nothing.
I would start checking for damaged wiring or connectors IMHO
2012 Vegas 8 Ball
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
post #6 of 11 (permalink) Old 05-26-2015, 06:44 PM Thread Starter
Savorino's Avatar
The replaced speed sensor is a Polaris # 4011111
I have not found any wiring problems yet, but haven't spent that much time on her because of illness. still trying to get the ignition switch connectors apart yet for cleaning-inspection.
'03 V92C Stage-I
Savorino is offline
post #7 of 11 (permalink) Old 05-26-2015, 08:20 PM
Motorbikerx's Avatar
Thats really the only worry with owning and riding a modern, fuel injected, computerised machine...
Electrical gremlins.... A lot to be said for points, coils, carburetors, and good ol fashioned Speedo cables.
At least we could maintain and fix em.
Good luck with finding a remedy, at least in this day and age we have forums for information/misinformation.
My Honda 750/4 bobber had no speedo, rode it for years, before the speed cops got hungry and radars and cameras but.
Gotta take the bad with the good I guess.
Luck comes into it to with electrics, but if my bike stops and its not out of fuel or a bad battery. Then Im pushing.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 11 (permalink) Old 04-22-2016, 05:40 PM Thread Starter
Savorino's Avatar
I still would like to know, Please, what it is that the speed sensor is picking up or triggered by?
'03 V92C Stage-I
Savorino is offline
post #9 of 11 (permalink) Old 04-22-2016, 06:15 PM
comes off the front sprocket
post #10 of 11 (permalink) Old 04-22-2016, 08:41 PM Thread Starter
Savorino's Avatar
" comes off the front sprocket "
Thanks, but was hoping for something a little more specific. is there a magnet or piece of steel in the aluminum sprocket that triggers a pulse in the sensor??...or?
If it was the teeth on the pulley, then you would never be able to change tooth count, but some have. Also, I don't believe I've ever heard of aluminum triggering a pulse, but not all that worldly (or smart)
Thanks.
'03 V92C Stage-I
Savorino is offline
