12v switched power on 12 jackpot? - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 05-15-2015, 11:15 AM Thread Starter
jsims006's Avatar
Default 12v switched power on 12 jackpot?
590 Zumo, where can I hook this bad boy up that is switched power? I see 2 connectors under the seat, the manual says its for hid lights.
Is there an "accessory" connection somewhere on this bike?
2012 Victory Jackpot 106
Lloydz Torque Tubes
Power Commander V
RPW Thor 2:1
96 HP / 112 Torque
jsims006 is offline
post #2 of 4 (permalink) Old 05-15-2015, 11:34 AM
SilvrT's Avatar
https://www.victoryforums.com/showthread.php?t=28586
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #3 of 4 (permalink) Old 05-15-2015, 04:44 PM Thread Starter
jsims006's Avatar
Thanks for the link, I did see that thread, but I was hoping to tap into the accessory fuse somewhere, I want to keep it clean and as "factory" as possible. Any other ideas?
Lloydz Torque Tubes
Power Commander V
RPW Thor 2:1
96 HP / 112 Torque
jsims006 is offline
post #4 of 4 (permalink) Old 05-17-2015, 09:04 PM Thread Starter
jsims006's Avatar
Followup: According to the wiring diagram, there is a yellow/red and black circuit running the length of the bike that is supposed to be used for accessories.
It was under the seat buried in the nest next to the ecm. I tapped my zumo into there after routing that long ass cable along the main harness. Works perfectly!
I did some more tracing and found 2 other connections to that same circuit: one under the tank taped to the harness and one in the headlight bucket. Just in case anyone else is looking for this.
Lloydz Torque Tubes
Power Commander V
RPW Thor 2:1
96 HP / 112 Torque
jsims006 is offline
