Gas smell - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 08-16-2012, 09:02 PM Thread Starter
Azdave's Avatar
Default Gas smell
After riding in 100 degree heat put the JP in the garage and came out later to a strong gas smell. 2nd time it has happened. Any thoughts why?
Blame it on me
2014 HD Street Glide
2013 Vision Sunset Red
2006 Jackpot sold
2006 Vrod Screaming Eagle (sold)
1972 Kawasaki 1000
Azdave is offline
post #2 of 7 (permalink) Old 08-16-2012, 09:10 PM
CrossRoads's Avatar
What's the fuel level in the tank?
There is a vent line from the tank, and the hotter it gets, the more gas vapor will leave through it to compensate for gas expansion. It's normal, unless you're sreing gasoline drops on the garage floor.
CrossRoads is offline
post #3 of 7 (permalink) Old 08-16-2012, 09:46 PM Thread Starter
Azdave's Avatar
No gas dripping. About 3/4 tank full. Thanks I feel better
Blame it on me
2006 Jackpot sold
1972 Kawasaki 1000
Azdave is offline
post #4 of 7 (permalink) Old 08-16-2012, 10:16 PM
Tims_04V92TC's Avatar
I get that often at 1/2 to 3/4 tank coming home in the afternoon if I put the bike right into the garage with temps upper 80s and higher.
I assumed it was the heat from the engine causing the fuel to warm a bit more and venting. Much more noticiable if I left the bike in the sun for a few hours and the fuel in the tank is hot already. I have a small shop fan that I leave on to help cool the bike if I am closing the garage door quickly now. It seems to have helped.
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #5 of 7 (permalink) Old 08-16-2012, 10:20 PM
Luciferiad's Avatar
Not sure if this applies to the Jackpot, but I did this fix (with a slight modification using a vacuum cap instead of a bolt in the T-fitting) and it solved the problem on mine.
https://www.victoryforums.com/archive...hp/t-5697.html
Mine:
2011 Cross Roads, crimson red
Hers
2015 Vegas 8-Ball
Luciferiad is offline
post #6 of 7 (permalink) Old 08-17-2012, 05:10 AM
dtmmil's Avatar
It was in the 90s here the last couple weeks and i could smell some also on my vegas, just from the gas tank venting, like said, I leave my garage door open for a little bit also.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #7 of 7 (permalink) Old 08-17-2012, 01:04 PM
When it gets hot out gas will expand. There for you will get gas out of the over flow tube or you'll wind up with the vapors. Were talking for the most part 90's plus. If its 80 out side it could be 90 in the garage. Put a thermometer in the garage there cheap.
When it gets hot out do not fill tank all the way.
They always say to fill up in the morning cause thats when you get more gas for your money it hasn't expanded.
