Light switch not working, - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 05-15-2015, 11:08 PM Thread Starter
BP6666VR's Avatar
Default Light switch not working,
:banghead:
Ok small problem, my driving light is working but my BIG light only flicks on for half second when i flip the switch
So surly the problem is on the handlebar switch ....
But i cannot retighten the wires or check the switch COZ i cannot take it out .... See picture the white plastic is holding it together but after removing the screw it does not come out ... Coz it could be a loose wire or bad switch only ...
Any experience with this ??
Cross Country Tour 2014 [B]
BP6666VR is offline
post #2 of 9 (permalink) Old 05-16-2015, 12:55 AM Thread Starter
BP6666VR's Avatar
Better picture now 2 switches are easily removed but the lightbeam switch cannot get out
I used the multimeter to see if the switch is working, and it seems it does ...
BP6666VR is offline
post #3 of 9 (permalink) Old 05-16-2015, 04:53 AM
Its hard to tell from the pics, is there anything jumping out at you as broken?
Do you have a dealer access in Indonesia where you could purchase a new switch?
post #4 of 9 (permalink) Old 05-16-2015, 07:12 AM Thread Starter
BP6666VR's Avatar
Everything looks fine ... But that is the only switch i could not "remove" for inspection ... Or testing
Bit odd i could not remove it ??
Noooo if i would order one it would take month's from the USA .... But better to multimeter everything first then ??
BP6666VR is offline
post #5 of 9 (permalink) Old 05-16-2015, 08:49 AM
wspollack's Avatar
Originally Posted by BP6666VR View Post
:banghead:
A few questions:
When you say "big" light, are you talking about the low beam or the high beam on the stock headlight?
These driving lights: you added them? And where do they get their power from?
Last, this half-a-second test: are you testing this with the engine running, or the engine off (with the key turned to Acc. or something)?
Cheers,
Bill P.
wspollack is offline
post #6 of 9 (permalink) Old 05-16-2015, 10:22 AM Thread Starter
BP6666VR's Avatar
Hi wspollack
Sorry yes low beam is working fine
High beam if i flip the switch only 1/2 second the high beam works ... Only original lights and wirering ... No extra lights
But 1 year ago HID not stock bulb's
The test of the switch itself is with the contact OFF, so i can see the 3 wires change on the multimeter, never checked with contact ON
Could there be a possibility the button is not contacting correctly .... And why i cannot take out that switch . as you can see removing the other switches is not a problem ?
Thanks for the questions, and correction, for high / low beam button
BP6666VR is offline
post #7 of 9 (permalink) Old 05-16-2015, 10:31 AM
wspollack's Avatar
Hi wspollack
I was just thinking that maybe there's a problem with a relay, because sometimes relays get involved with headlights. That is, sometimes -- and I'm not sure if this applies to Vics -- there's a relay and a delay in lighting up headlights when a bike is turned on. This process saves having the battery, at start-up, power both lights and the starter motor; once the motor's running, the headlights go on. That's how some bikes work, anyway.
So I was wondering whether there's a problem related to that sort of thing (if Vics do that). That's why I was wondering whether you have this problem after the bike's been fired up.
If you have aftermarket HIDs, then I suppose something could have gone wrong with the HID power source/ballast/something. I've read about a problem or two with aftermarket HID systems, some of which were replaced by a vendor and then worked fine.
Sorry, no help with the switches or how to take them apart. So far, you have me stumped...
Cheers,
Bill P.
post #8 of 9 (permalink) Old 05-16-2015, 10:38 AM Thread Starter
BP6666VR's Avatar
Ok getting your drift now, yes when the bike engine is running ALSO the same happening with the high beam
Ok i will check the relays in the morning, and i think the high / low ballasts are exactly the same, so i could try switching the ballasts ...
Good ideas mate .... Thanks, I'll update tomorrow .... Cross fingers
BP6666VR is offline
post #9 of 9 (permalink) Old 05-19-2015, 10:21 AM
depot picker's Avatar
My add-on HID would seem to flash when I turned it on. Within 5 or 10 seconds it would come up to full brightness.
depot picker is offline
