07 Vegas Dyno - Victory Forums - Victory Motorcycle Forum
post #1 of 24 (permalink) Old 08-21-2012, 09:30 PM Thread Starter
Default 07 Vegas Dyno
I dynoed my 07 Vegas tonite. Mods are S&S intake, RPW Slash pipes, and 05 Hammer S&S drag map.
Made 92 WHP and 100 torque.
Bike runs strong but is running rich, which is evident by the black soot on my exhaust. Would leaning it out some produce more power?
jzales84 is offline
post #2 of 24 (permalink) Old 08-21-2012, 09:41 PM
dtmmil's Avatar
Sorry I don't have much info on this, fuel injection on bikes is new to me. But you can't go by sooty tailpipes for your rich indicator, the gas we have to run now days is lousy at best so it will almost always leave soot. check your plugs to see what they look like. I am very interested in what you find out, I have an 07 vegas also that I want to tweek also, I will be keeping an eye on this post for sure!!!
How are the RPW slash pipes compared to the victory swept pipes? I have the swept pipes with RPW baffles in them.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #3 of 24 (permalink) Old 08-21-2012, 09:50 PM Thread Starter
Rpw slash are a night and day difference to my victory stage 1 shotguns I previously had on there. I know that the swepts are slightly better than the shotguns in terms of performance.
Once I put the slash pipes on I felt the difference immediately.
jzales84 is offline
post #4 of 24 (permalink) Old 08-22-2012, 05:50 AM
half_crazy's Avatar
Originally Posted by jzales84 View Post
I dynoed my 07 Vegas tonite. Mods are S&S intake, RPW Slash pipes, and 05 Hammer S&S drag map. Made 92 WHP and 100 torque.
That's very good for what you have. Bone stock is 75/92 so you picked up 17 HP/8 ft-lbs. Remember, the engine is still absolutely untouched... if you owned a Harley it would cost $4000 to make 92 HP.
There are better exhaust systems... there are better airboxes... but for what you're using you did really well.
There is no air/fuel graph shown, so it is impossible to tell if it's rich or lean. Soot is a normal byproduct of burning gasoline and is ineveitable. Stock bikes are lean as hell and have sooty pipes inside... think about it. As long as it doesn't blow black smoke when you get on it, and as long as the fuel mileage is reasonable, you're ok... Be happy.
2006 Victory Kingpin
half_crazy is offline
post #5 of 24 (permalink) Old 08-22-2012, 08:49 AM
Have to disagree with you about the swept pipes...they lose power. I had the Shotguns and they make great power to a point, then due to the small head pipe design they fall off quickly. My 07 Kingpin with S&S airbox, Shotguns, 05 Hammer map and VFC2 made 93 hp / 105 tq.
Evilive69 is offline
post #6 of 24 (permalink) Old 08-22-2012, 09:14 AM Thread Starter
I've seen dyno charts of the shotguns picking up just a few hp over stock... I did not try the shotguns with the s&s airbox so I can't comment on that but from my research the shotguns are known to be one of the worst performing pipe out there.
Your numbers make me want to dyno the bike with the shotguns on there since they are still sitting in my garage.
07 Victory Vegas 8 Ball
Rpw Slash Pipes, S&S Intake, Lloydz VM-1 Cams, Lloydz VFCII, Lloydz extended rev ecm, 1/4 turn throttle, Oem Tach Kit, Hammer V Bars, Barnett clutch, Bullet Headlight with HID, Ness black retro derby covers, Black ISO grips, Mbw led front signals, Black Ness rad II mirrors.
jzales84 is offline
post #7 of 24 (permalink) Old 08-22-2012, 09:20 AM Thread Starter
Here are some examples: http://www.lloydz.com/dyno.asp
jzales84 is offline
post #8 of 24 (permalink) Old 08-22-2012, 09:27 AM
I dont know of too many pipes that show a big increase with the stock airbox. I removed the cats from my shotguns and replaced the baffles with lollipops...it ran great and was loud enough to make blood squirt out of your eyes. The problem with the pipes is they won't flow over 98 hp or so.
post #9 of 24 (permalink) Old 08-22-2012, 09:34 AM
OkieHoss's Avatar
I agree with 1/2 if your mileage is good and your happy with it--I wouldnt worry about the soot Infact i would be happy if it was a little rich VS lean..nice numbers now go smoke a pig..
2013 black XCT.
OkieHoss is offline
post #10 of 24 (permalink) Old 08-22-2012, 10:17 AM Thread Starter
I'm fairly happy for $300 invested I got quite an increase... cams are next on the list of mods.
Any recommendation for a rear tire I'm having trouble keeping it from spinning on quick starts.
jzales84 is offline
