Belt tension - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 05-25-2015, 06:50 AM Thread Starter
philmonger's Avatar
Default Belt tension
I noticed that even though my belt tension is correct when I check it according to the manual, it gets tighter than a bulls ass with a fly on it once I ride it for a while...especially in the hot weather. I was considering loosening it up just a tad while it's hot. Anyrisk you guys can see to me doing this? Thanks in advance....
2011 XR Midnight Cherry, Hard Bags, Vic htd grips & seat, Vic medium Windshield, unlocked speedo, Lloydz Air filter, VFC III, Lloydz ATS +4, Vance & Hines slip ons
1993 Vulcan 1500 (sold)
1981 Yamaha Seca 750 (ridden into oblivion)
1977 Honda 550 (sold)
philmonger is offline
post #2 of 12 (permalink) Old 05-25-2015, 07:30 AM
If you have it adjusted properly when cold, then you should not modify this adjustment because it gets tight when hot. The highly capable engineers who designed the bike and created the belt tension specification have already taken this heating/tightening into account in the specified tension.
G'day,
Vinish
Vinish is online now
post #3 of 12 (permalink) Old 05-25-2015, 07:47 AM
If you have a scale, check that your belt tension gauge is accurate.. Mine wasn't, it was off by 3lbs..
Mark-B is offline
post #4 of 12 (permalink) Old 05-25-2015, 09:02 AM
Lostintexas's Avatar
That is why it starts out loose. It should be pretty tight when hot. Not sure about your description, but don't fool with a warm belt.
I ride with the Force.
Lostintexas is offline
post #5 of 12 (permalink) Old 05-25-2015, 10:16 AM
Motorbikerx's Avatar
yeah loose when cold and tight when hot is correct.
mine even chirps a little on the first couple of leaves from the lights when it's cold so I know for sure its not too tight.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 12 (permalink) Old 05-25-2015, 11:31 AM
Checking your belt with one of these?
post #7 of 12 (permalink) Old 05-25-2015, 11:59 AM
Reading the owner's book you supposed to put valve stem at 6 o'clock and check. Then rotate valve stem to 9 o'clock and check. then 12 and 3 making notes along the way
So you do not check the belt in just one place
post #8 of 12 (permalink) Old 05-25-2015, 01:13 PM
You will get different deflection rates at different wheel positions, too..
Mark-B is offline
post #9 of 12 (permalink) Old 05-26-2015, 05:39 AM Thread Starter
philmonger's Avatar
Amazon Amazon
That's what I use! My concern is how freeking tight it gets when it's hot! You can hear it whine/howl/groan at low speeds. Not too loud, but you can definitely hear it
post #10 of 12 (permalink) Old 05-26-2015, 07:00 AM
depot picker's Avatar
If it groans when hot it is likely too tight. Take a flat off of each side when it's cold. Screw the guage. JMHO
depot picker is offline
