Belt Alignment? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 05-25-2015, 05:37 PM Thread Starter
Default Belt Alignment?
I just want to make sure I understand the manual correctly. My belt is riding hard on the left side of the rear pulley. In order to correct this I must first loosen off the left axle nut and then make a very minor adjustment to the left adjuster nut?
2012 HardBall
Sturgeon County, Alberta
Focker is offline
post #2 of 6 (permalink) Old 05-25-2015, 05:46 PM
are you sitting behind the bike and spinning the wheel forward?
you have to spin the tire forward to see wears its running.
post #3 of 6 (permalink) Old 05-25-2015, 05:54 PM Thread Starter
Yes I'm looking from the back of the bike and spinning the wheel forward
2012 HardBall
Focker is offline
post #4 of 6 (permalink) Old 05-25-2015, 06:26 PM Thread Starter
By golly I got her running true now! And the bloody chirping belt is history!
2012 HardBall
Focker is offline
post #5 of 6 (permalink) Old 05-25-2015, 06:26 PM
MC Hammer's Avatar
You spin the wheel backwards and adjust the belt all the way to the right side. Then spin the wheel forward until the belt just starts to move left.
I love the smell of Freedom in the morning... smells... smells like... Victory!
MC Hammer is offline
post #6 of 6 (permalink) Old 05-25-2015, 07:20 PM
TNXR's Avatar
No matter what you do the belt will end up in a different place depending on temps and if you riding solo or with a passenger. I gave up 2 years ago trying to get mine to run in the middle. I just check deflection at every oil change and forget the rest.
2011 Cross Roads Sunset Red
TNXR is offline
