shift linkage lube - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 05-27-2015, 02:15 PM Thread Starter
irv
irv's Avatar
Default shift linkage lube
another stupid ? from me. what do you guys use to lube
the heim joints on the shift linkage. i try to flush each one
and either use a spray oil that turns to grease or wd40.
just wondering what your favorite is or something better i
can use. thank you for any help!
update-- kinda funny. just looked in the general section and vj
had posted something on shift linkage at the same time.
linkage lube is important.
mph faster].
irv is offline
post #2 of 11 (permalink) Old 05-27-2015, 04:52 PM
ByteN2it's Avatar
I use a lot of DuPonte teflon dry wax lube around the shop. The multi-use is great for most stuff (cables, hiem joints) and they changed their heavier bodied wax lube, now called Chain Saver that works in places you would use grease. There's also a thin TFE dry lube that works on everything-belts, guns, zippers, snow shovels/blowers, circular saw blades, etc. WD-40 is a great solvent, cleaner, water displacer- but not that great of a lubricant in my opinion.
ByteN2it is offline
post #3 of 11 (permalink) Old 05-27-2015, 05:03 PM
SilvrT's Avatar
Definitely not a lubricant!
Honda Moly 60 is a good product.
As for the OP's question, I spray a bit of motorcycle chain lube onto the linkage.
2013 RED XCT
Live to Love - Love to Ride
Life's a Venture on my Victory
Lloydz Air Filter
Lloydz Timing Wheel
Power Commander V
Autotune
CATs removed
Stage 1 flash
HD Trunk Rack
FIAAM Air Horn
PIAA 1100x Lamps
D&D Slip-on Mufflers
HID High & Low
KuryAkyn Sabertooth saddlebag tail lights
Victory Apes
Michelin Primacy Alpin PA3 ZP 195/55-16
SilvrT is offline
post #4 of 11 (permalink) Old 05-27-2015, 07:46 PM
half_crazy's Avatar
I use chain lube on the shift linkage and the kickstand pivot. Penetrates well, sticks, hard to wash off with rain...
2006 Victory Kingpin
half_crazy is offline
post #5 of 11 (permalink) Old 05-27-2015, 08:05 PM
BP6666VR's Avatar
I use an spray oil to clean the links, then i take vasaline as a grease when it is in sight and moly when out of site
Cross Country Tour 2014 [B]
BP6666VR is offline
post #6 of 11 (permalink) Old 05-28-2015, 07:15 AM
wspollack's Avatar
Er, um, could any of you folks post a pic or two -- maybe with added arrows, if anyone has time and feels creative -- regarding where to spray? I've never done any of this -- 29K miles on my XCT now -- with the exception of the kickstand.
Cheers,
Bill P.
wspollack is offline
post #7 of 11 (permalink) Old 05-28-2015, 11:15 AM
vaseline is a great way to grease nonstress parts.
post #8 of 11 (permalink) Old 05-28-2015, 02:41 PM
Lithium grease in an aerosol can with a straw type applicator to get it where the sun don't shine.
RICZ is online now
post #9 of 11 (permalink) Old 05-28-2015, 03:58 PM
Motorbikerx's Avatar
Castrol chain lube in a spray can with nozzle , cos I still got it left over from my chain drive bike days.
and yeah I squirt the pivot for the sidestand too, and the pivot points of brake lever.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #10 of 11 (permalink) Old 05-30-2015, 08:23 AM
Jamming's Avatar
Another chain lube guy here. Almost any lube is gonna be fine as long as you use it. That's the main reason I use it. Its on the shelf and handy.
I eat, breathe, live, love and ride motorcycles.
4 wheels move the body, 2 wheels move the soul.
Wiseco fueler, Lloyds timing gear +4, Thrush modded mufflers and LLoyds air filter.
Jamming is offline
