Timing wheel setting - Victory Forums - Victory Motorcycle Forum
View Poll Results: degree on the timing wheel
-2 1 1.05%
-1 0 0%
+1 0 0%
+2 2 2.11%
+3 2 2.11%
+4 67 70.53%
+5 9 9.47%
+6 14 14.74%
+7 0 0%
+8 0 0%
Voters: 95. You may not vote on this poll
post #1 of 49 (permalink) Old 05-30-2015, 09:58 AM Thread Starter
S.Bobber's Avatar
Default Timing wheel setting
I think it could be interesting for everybody to share the degrees you added/removed for those who have an adjustable timing wheel installed.
I see a lot of posts where some of you post their settings but it could be very helpful to have this centralized in one thread.
Can you also add your current setup? Thanks
2014 Victory HighBall
S.Bobber is offline
post #2 of 49 (permalink) Old 05-30-2015, 10:23 AM
really depends on the specific bike.....
.....that said...they start preset at +4 from Lloydz.
Peter
2013 Hammer 8-Ball
116" Supercharged
Brian Crower Rods
Lloydz Variable Clutch
Lloydz primary cover
Lloydz Billet Valve covers
Lloydz LSCams
PC V
RPW Big Slash
Penske rear shock
Conquest Customs Composite Rotors
Brembo calipers
PJRom is offline
post #3 of 49 (permalink) Old 05-30-2015, 11:38 AM Thread Starter
S.Bobber's Avatar
Peter
Yep, that's why you can see who votes and hopefully people have the setup of their bikes in the signature.
S.Bobber is offline
post #4 of 49 (permalink) Old 05-30-2015, 12:06 PM
Weeds's Avatar
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #5 of 49 (permalink) Old 05-30-2015, 01:22 PM
Pauljp's Avatar
I have a 2014 XCT and I started at +4, it ran great.
I moved it to +6 and noticed a bit of back firing and a bit harder to start.
I am going to move it back to +4.
I use 89 octane.
Paul
Gatineau Quebec, Canada
Pauljp is offline
post #6 of 49 (permalink) Old 05-30-2015, 07:44 PM
Motorbikerx's Avatar
Peter
Plus 4 on my Vegas as recommended,
Oh they may be preset at 4 but make sure ya tighten the bolts as theyre only nipped up lightly at assembly.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #7 of 49 (permalink) Old 05-30-2015, 08:35 PM
JoeyB's Avatar
+4 as shipped to me bike runs great. Never really tried any other settings but not getting any pinging and still running some advance in my PCV at higher RPMS. Definitely recommend Loctite on all the bolts when installing. If something comes loose inside the motor you'll be very sorry.
2011 Hammer 8 Ball
Hacker Rippers
PC V w autotune
Lloyds timing wheel
Ness Intake
MBW Rear LED's
MBW Plate Mount
JoeyB is offline
post #8 of 49 (permalink) Old 05-31-2015, 05:40 AM Thread Starter
S.Bobber's Avatar
Didn't any of you guys check the top dead center to make sure you use the correct degree without harming the engine?
It could be very bad if the degrees added with the timing wheel are not done properly
S.Bobber is offline
post #9 of 49 (permalink) Old 05-31-2015, 06:29 AM
kodiakwood2's Avatar
Started at plus 2, bike ran like crap, jumped to +4, bike runs great. Might try and bump up a little more
Eastern Tennessee
Current ride
2018 Goldwing tour
Gone but not forgotten...
Black/Chrome
Ultimate seat and driver backrest, Vic passenger backrest, Custom pinstriping by Dave Davies
Lloyds PTS @+5, Lloyds air filter, PC-V, Miller Mufflers, Lloyds Dyno-Tune,
Lloyds quarter turn throttle ring, Victory HID's, RicZ lay down bracket, Barnett "Stealth" clutch cable
kodiakwood2 is offline
post #10 of 49 (permalink) Old 05-31-2015, 09:22 AM
its installed on a keyway so no need to check TDC.
It can only go on in one orientation.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
