No longer displaying gear - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 08-27-2012, 08:47 PM Thread Starter
Exclamation No longer displaying gear
I have a 2011 Vegas 8-Ball with a little over 4000 miles on it. The spedo just stopped displaying what gear I am in. It shows the N when it is in Neutral but only shows a - when in any other gear. Everything else on the seedo works good. The bike seems to be running pretty good, however the clutch has been slipping a bit recently. I suspect that the problem with the slipping is that I went with Mobile 1 V-Twin oil instead of Vic oil on the last oil change. I am trying to decide if I need to make the 2 hour ride to my closest dealership to have them diagnose the issue with the gear display (Same reason I went with Mobil instead of Vic Oil). Honestly, if it does not indicate a larger issue I can probably live with it. What do you all think? Looking through the service manual I am not even sure what is used to determine what gear you are in.
Thanks for your help!
Victory8Baller is offline
post #2 of 18 (permalink) Old 08-27-2012, 10:17 PM
CrossRoads's Avatar
The first thing I would check is the gear indicator connector - make sure it's plugged in. Unplug it and plug it back, and make sure it clicks in place. I have highlighted it for you below to make it easier to identify.
If that does not fix it, you will likely have to replace it. Is your bike still under warranty? If yes, have your local dealer handle it.
CrossRoads is offline
post #3 of 18 (permalink) Old 08-28-2012, 12:08 AM
post #4 of 18 (permalink) Old 08-28-2012, 12:19 AM
CrossRoads's Avatar
Where on the bike is this located CR?
On the Cross bikes it's tucked behind the rear cylinder (top of the crankcase).
post #5 of 18 (permalink) Old 08-28-2012, 06:12 AM Thread Starter
Thanks. I will check it out.
Sent from my Galaxy Nexus using Motorcycle.com Free App
post #6 of 18 (permalink) Old 08-28-2012, 12:47 PM
Victory8Baller
Please add your state and model of bike. I could be just down the road to come over and help you. Ya never know where a helping hand might be.
post #7 of 18 (permalink) Old 08-28-2012, 02:07 PM Thread Starter
Just updated my profile. Looks like the problem is the gear position switch. It looks a bit different than the pic from the cross roads but that gave me what I needed to find it in the service manual (thanks!). Luckily the bike is still under warranty. I called the claims service and it turns out that one of the 'we sell everything but Harley' shops down the road is now a Victory dealer as well. Guess I will take it to them and have them replace it. I am a little nervous since I prefer to do all the work myself but I don't think the insurance will cover the part if I fix it myself.
post #8 of 18 (permalink) Old 08-28-2012, 02:14 PM
CrossRoads's Avatar
Yeah, it's minor repair, does not require any parts removed (other than side panels), so you can trust them with it.
post #9 of 18 (permalink) Old 09-15-2014, 10:11 PM
Travis P's Avatar
Does anyone know the outcome of this? I seem to have developed the same issue... Also my turn signal/horn/low fuel light fuse keeps blowing. Going to check battery cables and go from there. This is on my 13 Highball not my 14 XC.
Travis P is offline
post #10 of 18 (permalink) Old 09-16-2014, 05:49 AM
depot picker's Avatar
You need to adjust your clutch cable too. The Mobil 1 V twin oitl works fine.
depot picker is offline
