Got some water in my tailpipe... - Victory Forums - Victory Motorcycle Forum
post #1 of 28 (permalink) Old 05-31-2015, 05:01 PM Thread Starter
Default Got some water in my tailpipe...
Woke up to this today...
My street never floods but it decided to today. Had a lot of water and some small twigs and other debris go up the left tailpipe.
After the water went down I went out and the bike started right up. A bunch of water came shooting out. Let it run for about 5 minutes and seems like most of it is out now.
Anything I should do to make sure there's no internal damage?
jr222 is offline
post #2 of 28 (permalink) Old 05-31-2015, 05:22 PM
Pjv1k's Avatar
Holy crap!!!
2014 Pearl White cross country
2011 Mini Cooper Clubman S
Pjv1k is offline
post #3 of 28 (permalink) Old 05-31-2015, 05:36 PM
LILMAGS500's Avatar
If it fired right up and ran fine , I would say you are good to go !
LILMAGS500 is offline
post #4 of 28 (permalink) Old 05-31-2015, 05:57 PM
Travis P's Avatar
Did you just let it idle for a few minutes on start up?
Travis P is offline
post #5 of 28 (permalink) Old 05-31-2015, 06:02 PM Thread Starter
I did. Ran for about 5 minutes on idle before I gave it any throttle. When a did give it some gas a bunch more water sprayed out.
2012 Cross Roads
PCV, LLoyds intake, timing wheel and cams, V&H exhaust.
jr222 is offline
post #6 of 28 (permalink) Old 05-31-2015, 06:04 PM
rhino 2's Avatar
You're ok, When my kids were young they would hydro-lock my ATC in the pond, I would pull the spark plug and pull the recoil starter to pump out the water and all is well.. Being your bike was not running at the time don't worry...
If you don't wave to them'
They won't wave back to you....
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
post #7 of 28 (permalink) Old 05-31-2015, 06:10 PM
Dank's Avatar
At worst harden up the fiberglass inside making it less able to absorb sound. Just make sure to run it long enough to burn out as much extra moisture and find something to stuff the exhaust to help block out new moisture from the air from living in such a humid environment.
Dank is offline
post #8 of 28 (permalink) Old 05-31-2015, 06:10 PM
I would say go for a hour ride get everything good and hot to burn off and water and special get water out of the wheel bearings
post #9 of 28 (permalink) Old 05-31-2015, 06:10 PM
I would change the oil. Just in case any water got in. I would also unplug and spray wd40 in any electrical connections that were the under water
99 Kawasaki Vulcan 800 (sold)
2012 Vegas (traded)
2013 Cross Country Tour
Victory Tri-Ovals, Reverse Kit, Lloydz air filter, Lloydz quarter turn throttle ring, PCV, Lloydz Touring cams, HMD Bars, DGD keyless ignition, Rockford Fosgate Amp, klockworks windshield. 119hp 123lbs torque.
jchris56 is offline
post #10 of 28 (permalink) Old 05-31-2015, 06:50 PM
WOW!!!! That's some rain storm!! That's one of the reasons I live at the top of a hill. Plus, just in case the bike doesn't start it's easier to push start.
Vtwin1602 is offline
