Rear wheel pully bolts - Victory Forums - Victory Motorcycle Forum
post #1 of 10 (permalink) Old 06-01-2015, 07:31 PM Thread Starter
Wetland Destroyer's Avatar
Default Rear wheel pully bolts
I have my wheel off to get a new tire on I have a service manual they say replace these bolts anyone doing this?
2014 Cross country
Lloydz HOH-VM1-HPT-DR Cams, PC-V, , timing wheel, Lloydz air cleaner ,1/4 turn throttle and D&D unwrapped pipes Tuned to 123.97/115.94 By Rylan Vos at The Vic Shop.
Wetland Destroyer is offline
post #2 of 10 (permalink) Old 06-01-2015, 08:19 PM
depot picker's Avatar
I don't.
depot picker is offline
post #3 of 10 (permalink) Old 06-01-2015, 08:26 PM
my VW service manual said this almost always, asked the service guys + was told you just clean + locktite them, medium strength is usually the choice. stretch bolts must be replaced but are used sparingly in critical-special places. my 2013 Vic service manual says 70 ft lb in tightening in a star pattern, new bolts. look to see if threads are "dirty" a sign of factory threadlocker, your choice for sure! $3.53 ea @ victoryparts.net prolly same for all models
rodhotter is offline
post #4 of 10 (permalink) Old 06-01-2015, 08:57 PM Thread Starter
Thanks I will clean and locktite them.
2014 Cross country
post #5 of 10 (permalink) Old 06-01-2015, 11:10 PM
Motorbikerx's Avatar
Why remove the rear pulley to change a tyre???
No need to
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 10 (permalink) Old 06-02-2015, 12:26 AM
BP6666VR's Avatar
Depends on the tire machine ... I chucked my rear wheel and spanners in the back of my car, coz i had the feeling i would have to remove the pulley and break disk ....
And i had too ...
Cross Country Tour 2014 [B]
BP6666VR is online now
post #7 of 10 (permalink) Old 06-02-2015, 03:50 AM
And i had too ...
Oh ok, place that does mine has no problem handling wheel complete, so combined with my exhaust which negates sjock pivot bolt removal and the fact they know not to scree with my belt adjustment, makes tyre changing a breeze.
I drink coffee while they do all the work...to easy
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #8 of 10 (permalink) Old 06-02-2015, 07:23 AM
On a different brand bike, I changed the rear brake rotor which was put on with bolts with factory locktite (white color). The service manual said to replace the bolts. I removed them, cleaned them with a brass wire brush, put removable loctite on them, and reused the same bolts.
Since the service manual said to use permanent loctite on these bolts, I suspected this was what was used in the factory. To reduce the chance of breaking off one of these bolts or rounding the bolt head, I put a propane torch on the head of each bolt for about 30 seconds to soften the factory loctite prior to removing each bolt. This worked like a champ. Each bolt came out easily without any breakage or head rounding.
G'day,
Vinish
Vinish is offline
post #9 of 10 (permalink) Old 06-02-2015, 09:33 PM Thread Starter
You guys are right no need to take anything off note to self too late for me but might help someone else But thanks for the info all is back in working order.
2014 Cross country
post #10 of 10 (permalink) Old 06-03-2015, 05:37 AM
No need to
My cheapo bead breaker wouldn't accommodate my wheel with the pulley installed...
broggyr is online now
