Engine noise help! - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 06-06-2015, 09:43 AM Thread Starter
New Member
Tommysticks's Avatar
Default Engine noise help!
Hi Gang, My 2013 CCT has developed a strong high pitched whirling or winning noise coming from what seems to be the front of the engine. Itís mostly heard between 1800-2300 RPMís. I have searched the forums and have found many people with the same issue and the results of it being the belt alignment or bad pulley. Taking this advice, I have brought the bike into the dealer 2 times to have the belt adjusted and the noise has not changed, in fact it seems to be getting worse. What I have noticed now is that the noise can be heard at idle. It clearly is coming from the engine. Does anyone have any idea what this could be? The noise is so irritating that I donít enjoy riding.
Other factorsÖ
Just had the oil changed at the dealer.. No change in noise
2 Years ago the dealer installed the Lloyds timing gear, Cams, air filter and PC-V
Tommysticks is offline
post #2 of 11 (permalink) Old 06-06-2015, 09:49 AM
LILMAGS500's Avatar
My bike whines too , I always thought this was normal . My buddy told me it sounds like it has a supercharger on it , so yes its loud . Been like this since new though , it didn't just develop .
LILMAGS500 is offline
post #3 of 11 (permalink) Old 06-06-2015, 09:54 AM
LILMAGS500's Avatar
What did the dealer say they thought it might be , did they think it was normal ?
post #4 of 11 (permalink) Old 06-06-2015, 09:59 AM Thread Starter
New Member
The dealer has been going with the belt whine theory.. I am going back next week and leaving the bike with them. They said some whining noise is normal, but mine it extra loud.
post #5 of 11 (permalink) Old 06-06-2015, 10:08 AM
LILMAGS500's Avatar
Well , not the belt if its sitting there idling ... Keep us informed of their findings .
post #6 of 11 (permalink) Old 06-06-2015, 10:22 AM
rhino 2's Avatar
My Gunner makes all kinds of strange noises, I just figured its the nature of the beast being its the first Victory I've owned?
I just put my helmet on and Forgettaboutit.. The noises in my head cancel out the Vic's... Most noises will go away in time.
If you don't wave to them'
They won't wave back to you....
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
post #7 of 11 (permalink) Old 06-06-2015, 10:31 AM
LILMAGS500's Avatar
I agree rhino , my Hammer made all kinds of noises and so does my XC . Seems quite normal to me .
post #8 of 11 (permalink) Old 06-06-2015, 10:32 AM
philmonger's Avatar
I noticed you have the Lloydz AF...I just put one on my XR and I can definitely hear the air getting sucked into the engine. I would not call it a whine, buit it is kind of a whistleing noise....Definitely hear it at idle too.....
2011 XR Midnight Cherry, Hard Bags, Vic htd grips & seat, Vic medium Windshield, unlocked speedo, Lloydz Air filter, VFC III, Lloydz ATS +4, Vance & Hines slip ons
1993 Vulcan 1500 (sold)
1981 Yamaha Seca 750 (ridden into oblivion)
1977 Honda 550 (sold)
philmonger is offline
post #9 of 11 (permalink) Old 06-06-2015, 10:41 AM
Motorbikerx's Avatar
Gear drive primary whines, sound a lot like a blower or even a gear drive. I quite like the noise, coupled with my pipes and intake noise thru the Torquetubes its quite a mechanical symphony
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #10 of 11 (permalink) Old 06-06-2015, 11:41 AM
Tommysticks
you don't say do you have Lloydz air filter.
might be getting a whine or whistle out of there.
Motorbikerx is right you might be hearing the noise out of the primary. With all the gears in there meshing they could be making the sound.
Maybe a trip to Lloydz or Kyle would be better then your dealer
