Transmission slop? - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 06-08-2015, 10:46 AM Thread Starter
JohnnieD's Avatar
Default Transmission slop?
Maybe I never noticed or didn't hear it on my hammer but my XR seems to have a decent ammount of play in it. Most obviously noted when rolling on to off throttle, gets a good clunking kinda noise.
Eveyone's like this?
2014 Cross Road Classic
Atom Bomb mufflers
PC-V
Lloydz high flow air filter
Lloydz adjustable timing gear 5*
2009 Victory Hammer *SOLD*
Stage 1 kit
Lloydz 1/4 turn throttle
Victory touring seat
JohnnieD is offline
post #2 of 7 (permalink) Old 06-08-2015, 10:52 AM
navycraig's Avatar
The only noise I get is when actually shifting. After the hammer hits the anvil, all good.
God Bless America
U.S. Navy Retired
2012 Victory Crossroads Classic L.E. (#258)
PC V and Dyno tuned by Kyle of KMC
Lloydz High Flow Filter
Lloydz Timing Wheel
Lloydz Drop In Cams
Lloydz 1/4 Turn Throttle
Crossroads HID high/low lights
Making 113 HP and 115 TQ
navycraig is offline
post #3 of 7 (permalink) Old 06-08-2015, 11:29 AM
That's normal
vcc14 is offline
post #4 of 7 (permalink) Old 06-08-2015, 11:43 AM
rhino 2's Avatar
I get that with my Gunner, Mostly if I'm in the Low RPM range..
Doesn't happen above 25 hundred ..
If you don't wave to them'
They won't wave back to you....
2015 Gunner.
2011 Tri-Glide.
rhino 2 is offline
post #5 of 7 (permalink) Old 06-08-2015, 11:56 AM
Lostintexas's Avatar
Drive lash and yes they all have it to some degree or another. Not sure what the spec is on a Vic, but it was 1 1/2 in on my wing and about that on the Royal Stars. It isn't good comparison though because they were shaft drive. If you are really concerned, have the dealer check it or just call and ask how much it should be, easy enough to check at home.
Go easy on the throttle, when going off and on and it isn't very noticeable.
I ride with the Force.
Lostintexas is offline
post #6 of 7 (permalink) Old 06-08-2015, 03:32 PM
Could be that you are feeling the compensator more on your heavier bike.
It's working harder than it did on your lighter bike.
If you are not familiar with the guts of one here is one on ebay.
click on the picture that is farthest to the right.
http://www.ebay.com/itm/Polaris-Vict...ac56b7&vxp=mtr
Engine power drives one cam. Clutch and trans driven by the other.
They slide on each other and compress a big spring in the housing to remove the shock from the drive line. If you removed the spring they would just slide over each other and the bike wouldn't move.
Think of it as a primary connected to the transmission by a big honkin spring. That isn't a perfect explanation because if the spring is present eventually the two cams compress the spring solid both on deccell and accell and you have a solid mechanical connection. But until that happens there is a spring in the middle of the drive line. Pretty clever engineering really. Solves all kind of bad traits that Vtwins have at low rpm's and lets people run 6 speeds and such on modern engines.
Since your other bike was lighter and both used the same compensator you will feel more "slack" in your drive train as you accelerate and decelerate. The compensator on your heavier bike works harder than the one on your lighter bike when you ride normally and it might be the reason you feel more backlash or slack in the drive train.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #7 of 7 (permalink) Old 06-08-2015, 07:16 PM
My last two bikes were shaft drive so I am used to a lot more drivetrain lash than my Vic. Maybe the newer transmissions have more than the pre-2011's.
Gdfishwell Galveston,Tx 2008 Kingpin Tour Lloyd's timing wheel set at +3degrees, kuryakyn isogrips, kuryakyn throttle lock with matching left side bar end weight
gdfishwell is offline
