Charging Battery - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 09-03-2012, 10:23 AM Thread Starter
Default Charging Battery
Dead battery on the Vision; what amp setting should the charger be set on?
2011 Vision Tour
Tom Kirk is offline
post #2 of 13 (permalink) Old 09-03-2012, 10:33 AM
SilentUnicorn's Avatar
Is it a sealed battery? Be sure to top it off with distilled water, if it needs it, if it is not sealed. Generally I charge at 2 amps.
m
'12 Vegas, 78 Bonneville, 69 BSA project.
SilentUnicorn is offline
post #3 of 13 (permalink) Old 09-03-2012, 10:54 AM
Tom, how old is the battery? If its around 5 years and you haven't maintained it with an automatic trickle charger, especially during the winter, or you take short hops, I suggest a new one. If you don't have the aforementioned charger, by all means, get a quality one. If you are not going to use the bike in the next few days, put that charger on it. Many electrical parasites are at work draining your battery while you sleep. Same in your car.
post #4 of 13 (permalink) Old 09-03-2012, 11:14 AM Thread Starter
Thanks.
The battery is sealed and is less than 2 years old, it's the original.
Hope I don't have to replace it, really buried it in there didn't they?
2011 Vision Tour
Tom Kirk is offline
post #5 of 13 (permalink) Old 09-03-2012, 11:30 AM
Originally Posted by Tom Kirk View Post
Thanks.
There are some chargers that have the ability to restore batteries if they are not terminal. Pun intended.
You might want to complete your personal data and fill out a signature so we'll know what bike you have and what part of the world you live in. Do it before the moderator makes you stand in the corner for the rest of your life.
post #6 of 13 (permalink) Old 09-03-2012, 12:37 PM
Bat Man's Avatar
Check the battery voltage. If it is below 10 volts you may not be able to save it. It could have a short in one of the cells.
Make sure you have good clean connections on the terminals.
It depends on what type of charger you have. Most chargers are variable amperage. They give the battery as many amps as it can take up to a point. As the battery accepts a charge the amps go down. A very low battery may start out at 8 amps. It should tapper off to about .5 amps when charged.
Fully charged it will read 13.2 volts.
08 Kingpin 8Ball
Bat Man is offline
post #7 of 13 (permalink) Old 09-03-2012, 12:39 PM Thread Starter
Victory Vision Tour in a land where one can ride all year.
If one is not intimidated by excessive heat and a full time job.
Tom Kirk is offline
post #8 of 13 (permalink) Old 09-03-2012, 12:44 PM
Saudi Arabia???
post #9 of 13 (permalink) Old 09-03-2012, 01:12 PM
Never never use a car or truck to jump start a motorcycle battery.
Tom and the rest of you add where you live and year and model of bike.
If you read your owners manual it will tell you how to get battery out.
Once you get new battery in check your amp gauage it should be around 14.2 any thing less you might have bad stator or regulator.
post #10 of 13 (permalink) Old 09-03-2012, 06:40 PM
OldGringo's Avatar
After all it's all said and done, the answer to the OP is still 2 amps. Hope she holds the charge for you Tom.
Ride hard,
Gringo
Thin Blue Line LEMC
01 V92C
09 Vision
OldGringo is offline
