Throttle Point Reset - Victory Forums - Victory Motorcycle Forum
 4Likes
post #1 of 15 (permalink) Old 06-10-2015, 08:07 AM Thread Starter
Default Throttle Point Reset
I read this sticky with interest. What xactly doesn't do for you and when would you need to do this? Sorry. Am a newbie with Vics.
Hardright is offline
post #2 of 15 (permalink) Old 06-10-2015, 12:37 PM
you have to tell us what year and model you have first
post #3 of 15 (permalink) Old 06-10-2015, 04:50 PM Thread Starter
Oh. So sorry. I have a 2014 Cross Country.
post #4 of 15 (permalink) Old 06-10-2015, 07:30 PM
luvmyride's Avatar
There isn't a throttle point reset on the newer bikes.
Per Kevinx, one of the best Vic wrenches around
"Does not apply to 08 and up bikes"
2013 Black XC.
Victory Hard Lowers
Windvest 9" flip
Avon Boss Heated Grips
Hard mounted Garmin 665LM
VicBaggers:
23" Double Edge front wheel
+6 degree trees
Ridgeback front fender
Bag fillers
Tarzanz +2" bars
License Plate Relo kit
Contrast cut cam bolt covers
luvmyride is offline
post #5 of 15 (permalink) Old 06-10-2015, 07:55 PM Thread Starter
Oh well. Thank you for the quick revert.
post #6 of 15 (permalink) Old 06-12-2015, 09:37 PM
deadduck's Avatar
Hmm interesting, I have a 2012 xct. It's cammed, pcv, and tuned by the doctor. Tonight she stalled out when I stopped at the end of my road and then stalled four more times before I could get in a position to investigate. Did the tps reset per the instructions in the sticky and she's idling smooth as silk. This is the second time in the last few months I've been forced to use that method now I'm thinking I'll just do it randomly maybe each time I change the oil and lube the clutch cable. I'll have to give Kevinx a call Monday and see if he has any idea why she's doing it, maybe a loose wire or something.
2012 cross country tour
Modded stock exhaust (Jones a3512b)
PC 5
K&N pl1500
noise seal removed
Lloyds timing wheel at +5
Klock Werks flare windscreen
2004 Buell XB12r
1985 BMW K100RT
deadduck is offline
post #7 of 15 (permalink) Old 06-12-2015, 11:52 PM
BP6666VR's Avatar
It does not state in the sticky that it is only fot the earlier bikes, and if it works on PCV, would be nice to alter the sticky then ??
Key on, switch on, engine off
Slow 5 count rotate throttle from closed to wide open
Hold throttle wide open for slow 5 count
Let throttle SNAP shut/closed
Cycle kill switch (off then on)
Start bike, and enjoy the ride
Cross Country Tour 2014 [B]
BP6666VR is offline
post #8 of 15 (permalink) Old 10-11-2016, 02:12 AM
MaddogUSMC's Avatar
This is what I tried tonight! It seems to have done something. Maybe it's my imagination. I have a 2015 XCT and it's been sucking down gas. I hope to run into KevinX down in Daytona where he's set up and I'll ask him this weekend. Now I'm confused and not sure what to do!
2015 Victory Cross Country Tour 7/30/16 - 12/31/16
Lloydz ATS +4 and O2's disabled
Ultimate Seat and Driver Backrest
Alpine SPR-50 for front speakers and Polk Audio DB522 for the trunk speakers
Kuryakyn LED speaker grills
Michelin Commander II front and rear tires
Wolo Bad Boy air horn
Fusion LED kit for the whole bike
Tinted Klock Werks Flare (for winter riding due to fogging up)
Jax, FL
MaddogUSMC is offline
post #9 of 15 (permalink) Old 10-11-2016, 08:14 AM
Welcome to the club
MaddogUSMC likes this.
PaiN is online now
post #10 of 15 (permalink) Old 10-11-2016, 08:16 AM
NOEMTZ's Avatar
In doing the old TPS reset on 08-up. You inadvertently do a IAC relearn type procedure. When IAC voltage out of range, bike will idle strange and even stall out.
kevinx likes this.
www.noemtz.com
NOEMTZ is offline
