PCV with Auto Tune? - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 06-13-2015, 08:49 AM Thread Starter
steveg56's Avatar
Default PCV with Auto Tune?
I just getting ready to install my autotune unit AT-300 tonight and have watched as many videos as I can find for info. One thing no one touched on is, do you turn on Auto tune, then unplug your computer, ride, come home or pull over, keep engine on, plug back in computer, check trims and accept?
Does the computer need to stay plugged into the PCV while auto tuning? When you come back from your tune ride, do you have to keep the motor running till you accept the trims or will you loss the tune session if you turn off the motor?
2015 Magnum X1, AF, PTS, Vance and Hines Hi Outputs, PCV, AT-300
steveg56 is offline
post #2 of 12 (permalink) Old 06-13-2015, 10:43 AM
Computer used to initiate autotune and to input your numbers for the target af ratios. Unplug and go for your ride. Come back plug computer back in...with the bike on you accept trims. Everything is done with the bike on. Not in gear but idleing. Its a very difficult system to use but is the best option out there imho.
lykoi626 is offline
post #3 of 12 (permalink) Old 06-13-2015, 03:45 PM
ChiTownVegas's Avatar
I wouldn't say difficult to use, but the thing that gets me is why people say either a dyno tune OR autotune. I would think they would work well in conjunction since who knows what one particular bike likes for AFR/timing without a dyno
2012 Vegas 8 Ball
LLoydz VM1 drop in cams
LLoydz Adjustable Timing Wheel
LLoydz 1/4 turn throttle ring
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
Pirelli Night Dragon rubber
ChiTownVegas is offline
post #4 of 12 (permalink) Old 06-13-2015, 10:36 PM
dtmmil's Avatar
no, bike does not need to be on or running to setup or accept trims, only time it would need to be on is if you were trying to say set your idle af while inputting settings into your fuel map, auto tune is pretty easy to use
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #5 of 12 (permalink) Old 06-13-2015, 11:14 PM
Bike does need to be "on" to accept trims. Not running, but does need to be on
post #6 of 12 (permalink) Old 06-14-2015, 09:20 AM
Your bike needs to be running to check the wideband sensors...any change in fueling should be done on a warm bike. Customer support also stated there may be instances of maps not sending properly with a bike not running. I understand it technically just changing values. I was told to have the bike idleing so i do...never a problem. Is the system easy to use yes...is it something the average person with no knowledge of what is going on should do? Absolutely not. There is a learning curve. Just look at how many threads there are about a/f ratio setup. You owe it to your bike to read and understand.
lykoi626 is offline
post #7 of 12 (permalink) Old 06-14-2015, 09:35 AM
dtmmil's Avatar
NO IT DOES NOT!!!!! plug in to your laptop, check trims, accept trims, save map, send map, the key doesnt need to be in the damn bike even!!!
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #8 of 12 (permalink) Old 06-14-2015, 09:42 AM
lunaticrider's Avatar
Lol, No bike does not need to be "on" to work with or accept trims, the PCV will turn on once you plug it in to your CP/laptop.
To answer the OP's question, yes you can shut the bike off and the trims will be kept on memory until you accept them. I have used the PCV with AT since it came out (09) and have not heard or read that the key needs to be on, once the PCV has been powered up by your computer there is absolutely no need for the key to be on...
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
post #9 of 12 (permalink) Old 06-14-2015, 09:55 AM
dtmmil's Avatar
thank you sir!!
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #10 of 12 (permalink) Old 06-14-2015, 01:51 PM
Shrug.... I could be wrong as it's been over a year since I tinkered with it. Could have sworn I had to have my key/kill switch on.
2012 Vegas 8 Ball
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
