Engine light - Victory Forums - Victory Motorcycle Forum
post #1 of 11 (permalink) Old 06-14-2015, 11:18 AM Thread Starter
Default Engine light
First long ride on the 8 ball today and as soon as I gunned it off a roundabout the engine light came on and stayed on until I came to rest at a junction,then as soon as I pulled away it came back on again and behaved in this manner all day although it seemed to be running ok and no misfires. The bike is 5 years old with less than 3000 miles on it running the shotgun pipes stage 1 tuning with kn filter etc. Many riders here have pulled the o2 wires,I may try that to clear it.
2008 Suzuki B King,2010 Vegas 8 Ball,2006 BMW Z4.
goon is offline
post #2 of 11 (permalink) Old 06-14-2015, 11:41 AM
OkieHoss's Avatar
I doubt O2 disconnect will do anything. check the most basic of things like batt cables. good luck
2013 black XCT.
OkieHoss is offline
post #3 of 11 (permalink) Old 06-14-2015, 12:29 PM Thread Starter
Just nipped them up with a squirt of loctite to make sure.
goon is offline
post #4 of 11 (permalink) Old 06-15-2015, 11:57 AM
ChiTownVegas's Avatar
I assume you didn't check the codes? Not certain if the 2010 is the same, but I can pull mine up on the speedo.
2012 Vegas 8 Ball
LLoydz VM1 drop in cams
LLoydz Adjustable Timing Wheel
LLoydz 1/4 turn throttle ring
RPW Slash Exhaust
S&S Intake
PCV w/AutoTune
Barnett clutch
Pirelli Night Dragon rubber
ChiTownVegas is offline
post #5 of 11 (permalink) Old 06-15-2015, 04:17 PM
S.Bobber's Avatar
yea I've been told it could be the O2 sensors while unplugged. I happened to unplug them to run some tests and no light came up.
I would ask the dealer to check the error message. it happened to me a while ago but it was nothing. can't remember why actually.
2014 Victory HighBall
S.Bobber is offline
post #6 of 11 (permalink) Old 06-16-2015, 05:56 AM Thread Starter
Codes on speedo? Tell me more.
goon is offline
post #7 of 11 (permalink) Old 06-16-2015, 06:37 AM
Using the mode button for the display... You can select chk eng or similar to have it tell you the codes set
post #8 of 11 (permalink) Old 06-16-2015, 07:11 AM
Motorbikerx's Avatar
Did you clean the points of contact on the terminals and leads before reconnecting?
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #9 of 11 (permalink) Old 06-16-2015, 04:57 PM
S.Bobber's Avatar
And your dealer will be able to tell you what the code means.
You can find it in the doc coming with the bike too I think.
S.Bobber is offline
post #10 of 11 (permalink) Old 06-17-2015, 10:45 AM Thread Starter
Nope,nothing in manual mentioning any error codes or the like,must be on later models maybe.
goon is offline
