Drive belt - Victory Forums - Victory Motorcycle Forum
post #1 of 16 (permalink) Old 06-16-2015, 04:37 PM Thread Starter
ditech's Avatar
Default Drive belt
If the belt is to loose it chirps, it its to tight it groans. If it is adjusted right is it supposed to be whisper quiet? Mine is adjusted to spec on my cross roads and makes a light whirling noise from the rear pully when traveling fast
How does yours sound?
ditech is offline
post #2 of 16 (permalink) Old 06-16-2015, 05:22 PM
screw the specs. Get it so it tracks in the middle of pulley with about 1/2" up and down play.
If you think your belt is right go for ride and when you get around 60mph take your hands off the bars. If bike goes quick left its not correct. It should go straight and "slowly" right. If it goes fast right its not correct.
If it goes straight and you have the sound you could have a bad pulley.
Dealers have replace belt and pulley under warranty
of coarse it would of been nice if you said what model and year you have
post #3 of 16 (permalink) Old 06-16-2015, 06:07 PM Thread Starter
ditech's Avatar
It's a 2012 cross roads classic le
The specs says 1/1/4" up and down
So it should make no noise at all? I can only hear a whirling noise around 69 mph if I pull in the clutch and let the bike coast. If cruising exhaust sound covers up the sound
ditech is offline
post #4 of 16 (permalink) Old 06-16-2015, 09:47 PM
depot picker's Avatar
Roughly 1 1/4 and quiet.
depot picker is offline
post #5 of 16 (permalink) Old 06-16-2015, 11:22 PM
THAT IS WRONG, WRONG, WRONG! Bike on lift overnight cold....half way between the pulleys, push up 10 pounds worth and the belt should move up 1-1/4". Do that ever 1/4 turn of the rear wheel. Get yourself one of these....
post #6 of 16 (permalink) Old 06-17-2015, 01:38 AM
LOL.
Do you have a stock exhaust or are you pulling in the clutch at speed to hear the belt?
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #7 of 16 (permalink) Old 06-17-2015, 04:33 AM Thread Starter
ditech's Avatar
http://www.amazon.com/OTC-4748-Belt-...+tension+gauge
sorry youre right I ment to say up 1 and 1/4" which is what I have. I do use the gauge.
ditech is offline
post #8 of 16 (permalink) Old 06-17-2015, 04:37 AM Thread Starter
ditech's Avatar
Originally Posted by Joe_ View Post
LOL.
LOL I have the stage one kit. I pull in the clutch to listen to the belt. Im obsessive compulsive disorder I think. LOL Everything needs to be perfect.
I cant hear it unless I pull in the clutch and let the bike coast. If I'm on the throttle the exhaust noise covers up the belt noise.
So now.....should the belt make any sound at all or whisper?
I would assume some sound should be there right doing 60 mph?
Thanks for the input guys.
There's no other Vics around here I can compare mine to.
ditech is offline
post #9 of 16 (permalink) Old 06-17-2015, 06:57 AM
Motorbikerx's Avatar
Definitly OCD...Just ride the thing
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #10 of 16 (permalink) Old 06-17-2015, 09:41 AM
dtmmil's Avatar
you would go absolutely nuts with mine, i live in gravel, belt will be quiet on my way to work, squeek like crazy at noon, and quiets down again on my way home, if i can stay off the gravel, its quiet always, but i cant.
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
