Weird brake light/turn signal problem - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 06-18-2015, 08:32 PM Thread Starter
victorynurse's Avatar
Default Weird brake light/turn signal problem
Hey guys, I'm hoping someone can offer some advice. When I first bought my 2013 hammer 8ball I got rid of my front and rear turn signals. I replaced the rear with an LED strip flush to the bottom of the fender that incorporates both brake and signal lights and I put some fork wrap LED signals up front. Everything worked with no issues, but I did opt to leave out the voltage regulator that slows down the flash rate. So, fast forward a year later and I've just done my exhaust, intake, timing gear and a VFC III. Of course after this I got it dynoed. Strangely enough, since the dyno, anytime my blinkers are on and I apply either the front or rear brake the signals all stop flashing until I release the break??? Upon further inspection I've also realized that the ticking sound that accompanies the signal flashing that comes from the turn signal connection located behind the fuse box under the seat also ceases when the brake is applied. I've checked all the connections I can find and tried disconnecting and reconnecting the previously mentioned signal connection with no luck. It shouldn't be a fuse as a fuse to my understanding is an all or none situation. I've looked at my victory service manual, but to be honest the signal and brake connections schematic might as well be in chinese. Anyone have a similar issue or worthwhile suggestion before I spend a bunch of money to have it looked at?
Go BIG or go home!
2013 Hammer 8Ball
Side mount plate
Rear LED turnsignal/brake light
Debadged
Fork wrapped front turn signal
Pro One mirrors
Octane exhaust
Torque tubes
VFC III
Adjustable timing gear
Previously owned...
2007 Honda VTX 1300S
2009 Suzuki M50
victorynurse is offline
post #2 of 4 (permalink) Old 06-19-2015, 03:54 AM
Try disconnecting the brake light. If the directionals still cut out when you hit the brakes you might have nicked a wire when you were doing the new work.
If the directionals work without the brake light connected the problem is probably inside the combination brake/tail/directional unit. Just to be sure you could hook up the old directionals and brake light.
If I had to guess I would say it's the combination brake/tail/directional unit. A lot of those LED units are not made very well and end up being headaches after awhile.
2009 Vegas 8 Ball
2005 Ducati 749
1999 Ducati 748
Blake is offline
post #3 of 4 (permalink) Old 06-24-2015, 11:07 PM Thread Starter
Hey, thanks Blake. I'll be taking off the rear fender and going over the wiring this weekend. Hoping I don't have to replace these blinkers already.
Go BIG or go home!
2013 Hammer 8Ball
Side mount plate
Debadged
Pro One mirrors
Octane exhaust
Torque tubes
VFC III
Previously owned...
2009 Suzuki M50
post #4 of 4 (permalink) Old 06-25-2015, 06:03 AM
DirtyDan's Avatar
Interesting. After reading this and remembering back now my turn signal indicator issue didn't rear its head until I installed the PCV. Hmmmmm
All sold
2012 XCT,
03/07/12 RG Chopped Bagger
1996 Road King Chopped
2003 FLHTCUI
2003 Big Bear Choppers DA
2000 Chopper Guys rigid EVO
1947 Knuckle
1990 FXRS Convt
1986 Honda CX650C
DirtyDan is offline
