Exploding Clutch Saga Over??? - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 06-21-2015, 07:57 AM Thread Starter
Default Exploding Clutch Saga Over???
After having my CCT sit at the dealership since 6/10 I finally have her back and Ma Victory picked up the tab for an entirely new clutch. According to the dealer when all said and done it will cost about $2,100 to replace everything. The dealership also changed the oil after replacing the clutch, rode it for a few miles and replaced the oil and filter a second time saving me from doing it.
Since picking the bike up Friday I've ridden just over 320 miles and the first thing I noticed is my shifts are a little smoother and the clutch feels better. So I'm wondering if what I thought might just be getting use to the bike was really the clutch failing??
At this point everyone from me, the dealership and Ma Victory are still scratching their heads regarding what happened. All the parts have been sent to Victory and the dealership took over 20 pictures that were requested. Will there be a recall? I doubt it, but the exploding clutch is now known about and hopefully they'll go back to the parts manufacture and investigate their process.
I'm back in the saddle again and a very happy fella
Vtwin1602 is offline
post #2 of 19 (permalink) Old 06-21-2015, 07:59 AM
LILMAGS500's Avatar
Great news Brother , glad your back , and happy .
LILMAGS500 is offline
post #3 of 19 (permalink) Old 06-21-2015, 08:05 AM Thread Starter
After what happened, I'm still a little nervous every time I pull the clutch in. But that will pass...
post #4 of 19 (permalink) Old 06-21-2015, 09:01 AM
Weeds's Avatar
2013 XCT, Red,
Tri Ovals, S1 Package, Accel 8.8 Wires,Yellow.
Wheel @ +4, Kuryakyn Shift/Brake Pegs, o2s Disabled.
Utopia Backrest. KewlMetal Heal Shifter with Kuryakyn pegs ..
Lubrication Provided By Amsoil..
Even duct tape can't fix stupid....but it will muffle the sound
Weeds is offline
post #5 of 19 (permalink) Old 06-21-2015, 09:23 AM
vindex1963's Avatar
Now hopefully you can just enjoy the ride.
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is offline
post #6 of 19 (permalink) Old 06-21-2015, 09:35 AM
BP6666VR's Avatar
Great man, happy for you .... Did the dealer told you to change oil before 5000 mile because of the new clutch ?
Maybe oil analysis would be an option for you at 2500 miles ?
Happy riding my friend
Cross Country Tour 2014 [B]
BP6666VR is offline
post #7 of 19 (permalink) Old 06-21-2015, 10:10 AM
RLinNH's Avatar
Even I am a little timid now what with all the clutch related issues I am reading about here on these forums.
Great news that the dealer took care of you. Ride on!!!
2015 GI Olive Drab Green High Ball
Lloydz Torque Tubes
Lloydz Advanced Timing Wheel
Lloydz VFC III
Conquest Customs Octanes
RLinNH is offline
post #8 of 19 (permalink) Old 06-21-2015, 11:45 AM
Vtwin1602
great your up and going with money in your pocket.
I was thinking oil filters are cheap so why not change it at say 500 or 750 miles as a precaution.
Happy miles to you
post #9 of 19 (permalink) Old 06-21-2015, 01:12 PM
Can't blame you but like you said; it'll pass and you will regain confidence in your bike. The vast majority never have any issue with the clutch other than at some point with normal wear and tear; the plates need to be changed.
Vtwin1602
Happy miles to you
You're right enough about oil being cheap enough if you go with something other than Vic oil or Amsoil but why not just change the filter at that point then go ahead and change the oil and filter at the regularly scheduled interval at 5k miles so it will be back on track? It's easy to keep track of 5k mile increments like 5, 10, 15, etc.
post #10 of 19 (permalink) Old 06-21-2015, 04:42 PM Thread Starter
They didn't come right out and say I should change the oil before the regular interval, but I'm going to put about 2k on the bike and do it just as a safe guard. One of the mechanics at work is rigging up a filter to drain the oil over so I can see if there was any noticeable metal fragments.
