XC-Oil Coating on Engine Fins - Victory Forums - Victory Motorcycle Forum
post #1 of 21 (permalink) Old 09-13-2012, 05:59 PM Thread Starter
RedRocker's Avatar
Unhappy XC-Oil Coating on Engine Fins
I'm doing my weekly engine oil check tonight and I notice a coating of oil on the rear facing cooling fin, about midship on the head. See photos. I really can't determine where the oil is coming from, but it doesn't seem to be coming from the exhaust flange.
Oil level is where it was at last week. So fellas, what the hell do I have going on here? I haven't noticed any loss of power and I've been riding every day this week. I'm reaching out to my mechanic to describe what I found.
Just shy of 9K on the XC and you can see my mods below. Thanks.
Dave
USCG Retired
2014 Sonic Blue/Silver XCT
Lloydz VM1-DR Cams/ATS/Air Filter/.25 Turn/PCV/Vic BlkTip Tri-Ovals/Tuned by KMC Powersports: 111/112 CR's H/L HID Kit/Glenda LED's/Hyperlites/Stebel Air Horn/Vic Black Billet Floorboards-Primary&Cam Cover
2011 XC-Traded
RedRocker is offline
post #2 of 21 (permalink) Old 09-13-2012, 06:20 PM
gibson's Avatar
sounds to me like a exhaust leak
2012 Fireball Jackpot
gibson is offline
post #3 of 21 (permalink) Old 09-13-2012, 06:27 PM Thread Starter
RedRocker's Avatar
Post
When I first laid down on the driveway to get a better look, I thought that was where it was coming from too. I ran my finger around the exhaust and there really wasn't any residue. But, it certainly makes sense that would be the suspect location.
Do you know if these exhaust fasteners need to be torqued down? Thanks much.
Dave
USCG Retired
2011 XC-Traded
post #4 of 21 (permalink) Old 09-13-2012, 08:16 PM
Lloydz gaskets alledgedly prevent that. You can put a wrench on the exhaust bolts and be sure they're tight. If it is the exhaust...more popping should have been occurring. What's the diagnosis from KMC?
2010 XC Midnight Cherry
cams/D&D
2009 Ness Vision
116 Big Bore
"The Millinium Falcon"
Blueline is offline
post #5 of 21 (permalink) Old 09-13-2012, 09:02 PM Thread Starter
RedRocker's Avatar
Post
I put the Lloydz gaskets in when I had the D&D's and Cams installed. Hasn't seemed to be popping anymore than it usually does, which isn't very often.
I'll give KMC a call in the am. Thanks much.
Dave
USCG Retired
2011 XC-Traded
post #6 of 21 (permalink) Old 09-13-2012, 09:09 PM
Buellx72's Avatar
It may seem weird but check the top connection on the crank case breather tube. It has a rubber connector on the throttle body.
I've seen this work it's way loose and drip oil on the front of the fins, where it's hard to see. The oil then migrates down to the lower side of the jugs where it can be readily seen.
Hope whatever is wrong, it's an easy fix!
Bill
Sent from my Motorcycle iPhone app
2012 Cross Country Tour Sunset Red
Lloydz air filter
PCV w/ AT
D&D wrapped pipes (unwrapped now)
2013 Vision Tour
'07 Road King Sold
'00 Buell X1 Sold
'72 Sportster (In Pieces)
Buellx72 is offline
post #7 of 21 (permalink) Old 09-14-2012, 04:10 AM Thread Starter
RedRocker's Avatar
Post
Thanks Bill, I'll check that out today.
Dave
USCG Retired
2011 XC-Traded
post #8 of 21 (permalink) Old 09-14-2012, 07:02 AM
Roughrider's Avatar
Default ASM - Breather Tube -
RedRocker,
Believe Buellx72 is correct. At or around 2K miles, noticed oil on my fins. Took the tank off to get a better look. The rubber peice that is attached to the ASM - Breather tube (#8) had split in several areas. You have to purchase the whole thing unless it is under warranty. I did not want the heat and or oil fumes going back into the engine. Plugged the end at the top of the motor. Then at the bottom ran tube out the bottom of frame. Works great!!
Stay Safe and Live long,
Roughrider
2011 Cross Country
Roughrider is offline
post #9 of 21 (permalink) Old 09-14-2012, 03:50 PM Thread Starter
RedRocker's Avatar
Post
RR,
Thanks for the detailed post. I'll let you know what I discover.
Dave
USCG Retired
2011 XC-Traded
post #10 of 21 (permalink) Old 09-18-2012, 04:38 PM
So.....did you get to the bottom of this?? Resolve the issue?
cams/D&D
2009 Ness Vision
116 Big Bore
Blueline is offline
