Fork Oil Level/Filling? - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 06-25-2015, 09:07 AM Thread Starter
Gore's Avatar
Default Fork Oil Level/Filling?
Part of my triple tree install requires me to install limiters, so the forks have to be opened up.
I am thinking that I will switch to 15W oil at the same time as well.
I'm a little fuzzy about how to properly fill the forks, and what the proper level is for a 2014.
Can someone chime in please?
Also, the bike only has like 250 miles on it.
2014 Cross Country w/ABS Metallic White
Big Honkers Exhaust, Flux Capacitor
Gore is offline
post #2 of 9 (permalink) Old 06-25-2015, 12:23 PM
call the guys that you got the trees from and ask them. They would know more then what we would. Ask about what weight oil would work best and tell them how much your weight is that will help them
post #3 of 9 (permalink) Old 06-25-2015, 12:43 PM Thread Starter
Gore's Avatar
Good advice, I assumed the forks would just need to be filled to a standard level...and everything else would be accounted for by the weight of that oil.
Gore is offline
post #4 of 9 (permalink) Old 06-25-2015, 02:25 PM
vindex1963's Avatar
You're going from 7w to 15w you like a "firm" ride don't you?
1/4 turn throttle ring
Tank riser
VM-1 DR cams
Timing wheel +4
Lloydz high-flow air cleaner
Bassani baffled OEM mufflers
PC-V 118hp 116tq
vindex1963 is online now
post #5 of 9 (permalink) Old 06-25-2015, 04:07 PM Thread Starter
Gore's Avatar
I had planned to go with 15w after talking to others that used the same trees.
I actually just got off of the phone with VicBaggers and Eric wasn't there, but they tried to help as best as they could.
They recommended 20w...I'm about 225, and ride with a passenger at times. I think 15w might still be a happy medium.
They also just said to put in what I take out as far as oil goes.
I bought the syringe tool, so if someone knows what is factory on a '14 please chime in.
Also, I have seen videos of people filling the forks with the springs in...and read somewhere (on here I believe) that you should fill it prior to reinstalling them??? Which way is correct?
Gore is offline
post #6 of 9 (permalink) Old 06-25-2015, 05:07 PM
kevinx's Avatar
Personally I skip the limiters with a 23. Move to 15w, and fill it to a highr 15mm higher then stock. Higher level reduces compressible air chamber, and that firms it up. The heavier oil increases the dampening
kevinx is offline
post #7 of 9 (permalink) Old 06-25-2015, 05:33 PM
Motorbikerx's Avatar
Fork limiters and heavy oil.
Its gonna ride like shit anyway,
Just avoid bumps.
Oh and get another Vic to actually ride.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #8 of 9 (permalink) Old 06-25-2015, 06:59 PM
kevinx's Avatar
Just avoid bumps.
When you change the attack angle of the front wheel by raking it. You effectively soften the ride, and it has to be firmed up a bit. I don't like the limiters though personally
kevinx is offline
post #9 of 9 (permalink) Old 06-25-2015, 08:20 PM Thread Starter
Gore's Avatar
Have you guys mentioning to skip the limiters actually installed the VicBaggers kit? I won't lose any sleep over not having to build a spring compressor and fuss with it.
Gore is offline
