EBC pad problems - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 06-26-2015, 04:16 PM Thread Starter
ostbob's Avatar
Default EBC pad problems
I installed the FA196HH rear pads on my 2012 xct and it started making a hell of a noise right at the point the bike settles after a complete stop. Not a squeak, but a really loud metal to metal sound.
I called EBC and talked to a tech guy who said if shims were needed they would have included them in the package so remove the OEM shims which I did.
It still makes the same loud noise and now I can't get a return phone call from EBC.
I pulled the new pads and notice what looks like rubbing marks where the pistons touch the Pads, I'm sure thats what making the noise.
Anyone else have this problem and is anyone else installing the OEM shims on aftermarket pads,
Bob
Retired law enforcement
Ex-USCG
2012 Victory XCT,
floor board skid plates,
tankslapper 3M paint protection.
Magic Strobe modulationg trunk brake lights
2" pull backs
Russel Day Long seat
Kriss Industries Headlight modulator
Doran tire pressure monitoring system
ostbob is offline
post #2 of 13 (permalink) Old 06-26-2015, 04:33 PM
LILMAGS500's Avatar
I'm confused , in another recent thread , everyone is toting how great these pads are ....
LILMAGS500 is offline
post #3 of 13 (permalink) Old 06-26-2015, 04:52 PM
Watching...
post #4 of 13 (permalink) Old 06-26-2015, 06:10 PM
dtmmil's Avatar
i just installed these on mine, i chamfered the leading edges, but mine didnt have and shims on the rear pads, mine are quiet
currently bikeless
2012 Cross Country(Imp blue)
Hawley MN(sold)
dtmmil is offline
post #5 of 13 (permalink) Old 06-26-2015, 06:57 PM
Ostbob, that sound is a high frequency set up between the pad backer and pistons.
Did you notice any thin, perforated sheet metal devices on the backs of the old pads and did you transfer them to the new ones? If you still have the old ones, check to see if they are there and if they are, remove them and put them on the backs of the new ones.
If there were no such shims, get some Brake Quiet and apply it to the backs per the directions.
post #6 of 13 (permalink) Old 06-27-2015, 09:06 AM Thread Starter
ostbob's Avatar
RICZ
The OEM only had a shim and insulator on the inboard side nothing on the piston side (See Pic of OEM and EBC.) and I have since thrown them away.
NO perforated thin sheet metal on either. Just a solid one and an insulator on the inboard side.
I can't seem to get the EBC tech to return my calls so now I need help from guys like you who have actually used them. But like I said I originally put the shims and insulator on the EBC and had this terrible noise (not a squeak). Removed them and still have the same noise.
When I look at the EBC pads where the piston touch the back it looks almost like the piston dug in or scraped the metal plate but hard to see in the pictures
But your suggestion is to use the OEM shim, insulator pad and a, brake quite lube?
Bob
Ex-USCG
2012 Victory XCT,
2" pull backs
ostbob is offline
post #7 of 13 (permalink) Old 06-27-2015, 09:15 AM
dtmmil's Avatar
take a grinder and bevel the leading edge slightly. i use to use duct tape on the back of my brake pads to quiet them.
currently bikeless
Hawley MN(sold)
dtmmil is offline
post #8 of 13 (permalink) Old 06-27-2015, 11:07 AM
+1 on beveling the leading edges. Use the shim OR Brake Quiet, which is a substance that that does not dry hard.
post #9 of 13 (permalink) Old 06-27-2015, 04:17 PM
BP6666VR's Avatar
First time i hear on this forum EBC problems, hope you can fix it
If you trew the OEM shimplates away then +1 on the ductape ... Thanks for posting this and hope you can fix it
Cross Country Tour 2014 [B]
BP6666VR is offline
post #10 of 13 (permalink) Old 06-27-2015, 06:46 PM Thread Starter
ostbob's Avatar
Followed all the advice from you guys, thank You.
Cycle Gear allowed me to exchange the EBC pads for new ones. I installed them allong with the OEM shims, and brake quiet. Glad I only trashed the OEM pads and not the shims and insulator after talking to the EBC Tech who obviously didn't know what he was talking about.
So far its working great but I need to seat the pads some more before I do any hard braking.
Bob
Ex-USCG
2012 Victory XCT,
2" pull backs
ostbob is offline
