rear suspension - Victory Forums - Victory Motorcycle Forum
post #1 of 8 (permalink) Old 06-27-2015, 08:59 PM Thread Starter
slyman's Avatar
Lightbulb rear suspension
Thinking of getting a progressive rear shock, can you give me some opinions? I don't mind paying for performance, but I don't like flushing money down the water closest. Seems like every shock is the'best' shock. I'd like to hear from guys who are in the know, or have them on their rides. Love to hear the pros and the cons
06 vegas 8ball
lloydz timing kit @5 degrees
lloydz torque tubes
trask hot rod, 2 into 1pipes
Pclll
lloydz drop in cams
1/4 turn throttle
2 inch lowering links
highball handlebars
113 hp 123 ft. Lbs. Torque
progressive shock
slyman is offline
post #2 of 8 (permalink) Old 06-27-2015, 09:19 PM
Motorbikerx's Avatar
I bought a used Progressive with 10,000 kms in it off a fellow Aussie forum member who went to a full air system.
The Progressive is Fantastic!
Waaay better than stock!
You can spend more on a Penske shock as they are even better with even more adjustability I hear.
Theres members here who run Penske shocks thatll tell you more, but for my budget and Vegas the Progressive shock is
Just great!
Both are good, just one is more expensive.
If money is no object go the Penske.
For mere mortals go the Progressive.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #3 of 8 (permalink) Old 06-28-2015, 12:01 PM
this is not mine know nothing about it
http://minneapolis.craigslist.org/da...030954930.html
post #4 of 8 (permalink) Old 06-28-2015, 02:43 PM
MC Hammer's Avatar
On little pavement ridges a steel rod would be better than stock imo.
That Penske for $500 seems very much worth a look.
I love the smell of Freedom in the morning... smells... smells like... Victory!
MC Hammer is offline
post #5 of 8 (permalink) Old 06-28-2015, 03:05 PM
blueracer17's Avatar
I have a 465 on my KP and it is night and day from stock. No more sharp hits to the spine. It was worth every penny I paid for it. That Penske and CL is a great deal and could probably be had for the same price as a new Progressive. Regardless, you will not be flushing your money down the drain with a new shock. They are rebuildable and will last the life of the bike and then some.
2004 Kingpin
Mustang Seat, Progressive 465 shock, RPW Thor Exhaust, VFC III, S&S Intake, Ness Fly bars, Kuryakyn ISO Grips and throttle boss, Kuryakyn Silver Bullets, Ness laydown plate bracket, Barnett braided clutch cable....
blueracer17 is offline
post #6 of 8 (permalink) Old 06-28-2015, 08:10 PM
SMTCapeCod's Avatar
Default 465
Just... JUST installed 465. Replaced what I believe was original shock on '06 Vegas thus 15K worth of wear on orig. Have less than a 100 miles on the replacement.
I left the new shock on the recommended middle setting 3.
I notice a slightly busier ride over small road imperfections, not exactly equivalent to a sporty ride in a car, but not problematic. I notice much improved control over very large road imperfections- very large heaves and dips. So, I think the compression is stiffer and the rebound is much better than the orig, which may have worn.
All in all, a pretty hefty price tag for my DD which sees routine rather than sporty driving. Of course, it may improve with break-in and further dialing-in.
I opted for non-lowered shock paired with my inverted hammer forks.
2006 Vingpin, Inverted forks, Progressive rear shock, Stage 1 slip-on kit, S+S intake, grips and pegs, tach and rack, corbin saddle, night dragons. KMC reflashed/retuned to 100HP/104 TQ, good'nuff.
2014 BMW 650i Xdrive
2005 Grand Cherokee Ltd 5.7L Hemi, Konis, SRT swaybars, BB
1986 Porsche 928S, slightly enhanced.
SMTCapeCod is offline
post #7 of 8 (permalink) Old 06-28-2015, 08:21 PM
Originally Posted by SMTCapeCod View Post
Just... JUST installed 465. Replaced what I believe was original shock on '06 Vegas thus 15K worth of break in. Have less than a 100 miles on it.
Did you adjust the main coil spring for sag(ride height)
That controls your compression damping.
The Allen setting on bottom is rebound damping.
Victory Vegas 2010
" " 495 cams
" " TorqueTubes
" " Primary plate
" " IAV
RPW Slash pipes
Kingpin USD Forks
18" XC front wheel
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
post #8 of 8 (permalink) Old 06-29-2015, 02:55 AM
Krisd's Avatar
Just great!
100% concur with MBX- I also have the Progressive rear.
2012 Hammer S
Freedom Performance pipes now wrapped, PCV, Loyds air filter, ATS, Loyds Cams and 1/4 Turn Throttle adj, Progressive rear shock
300mm rear and 23" front
Krisd is offline
