Hard start after Modifications; torque tubes, hacker rippers, loydz ats, IAC, PCV - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 06-29-2015, 02:20 PM Thread Starter
Default Hard start after Modifications; torque tubes, hacker rippers, loydz ats, IAC, PCV
Hey guys i have a 09 hammer s.
just added a bunch of parts.
-torque tubes w/ loydz IAC
-Hacker Rippers
-Adjustable timing gear set to +4
-power commander 5 setup by fuel moto for all my mods
now after i added all the parts i pushed it out of my garage and the bike started right up no problem. took it for a ride to a friends and around town started right up fine everywhere when hot. got home let the bike sit cooled down, went to go move it later on and it was turning over fine and firing but wouldn't stay running. sounded like it had started so i would take my hand of the starter and it would just die. will start fine if i give it a little throttle and hold it for a minute or too but i dont think this should be necessary.
could any one help? do you think it could be the tune? unsure if there is a warm up map or something on these bikes. i tried fiddling with the IAC, maybe i have to play with that a little more?
Jeepguy2310 is offline
post #2 of 6 (permalink) Old 06-29-2015, 03:24 PM
kevinx's Avatar
Turn the IAV out a good bit more
kevinx is offline
post #3 of 6 (permalink) Old 06-30-2015, 08:41 AM
Motorbikerx's Avatar
yeah...then once you get it running again turn the IAV screw in in 1/4 turns each time you ride....till it gets to the point where when you start it cold it wont idle, ..then back it out 1/4 turn.
Its a fine line between not idling properly and Snap Crackle Pop but its worth getting right.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #4 of 6 (permalink) Old 06-30-2015, 06:16 PM
dual pipes with a crossover perform better, the connector equalizes + quiets the sound a bit
rodhotter is offline
post #5 of 6 (permalink) Old 06-30-2015, 07:02 PM Thread Starter
thanks for the tips guys ill start fine tuning it
rod hotter not really what i was looking for but thanks
post #6 of 6 (permalink) Old 07-01-2015, 08:19 PM
jackwithcorona's Avatar
Also, try opening the throttle slightly when firing the motor up cold. Go to the Lloydz site and he has a startup procedure in a video for you.
2006 Suzuki SV650 (Traded)
2012 Victory Vegas 8-Ball (Traded)
2014 Victory Cross Country
1985 Harley XLH
jackwithcorona is offline
