Belt Alignment, Noise? - Victory Forums - Victory Motorcycle Forum
post #1 of 13 (permalink) Old 06-29-2015, 10:15 PM Thread Starter
deepstuff's Avatar
Question Belt Alignment, Noise?
Hi,
I have a 2008 Kingpin. I have noticed lately a faint chirping noise when going slow. Looking at my belt it seems to be running against the outside of my rear pulley. Marks on the edge of my belt confirm this. Is this normal? Should I adjust my belt and alignment?
https://www.dropbox.com/s/lay58u9hql...50001.jpg?dl=0
https://www.dropbox.com/s/sx84kqx3xw...50034.jpg?dl=0
Thanks!
2008 Kingpin Premium
Newfoundland,
Canada
deepstuff is offline
post #2 of 13 (permalink) Old 06-29-2015, 11:26 PM
sthxc83's Avatar
Originally Posted by deepstuff View Post
Hi,
Thanks!
The belts on Vic's, for whatever reason, are incredibly temperamental. If the alignment and tension isn't just right, they make noise (dirt in the belt teeth can also cause this).
That said, the belt should ride on the outer edge of th epulley ever so slightly and set to proper tension (not sure what the tension should be set to on your 'pin).
Mike
2013 Nuclear Sunset XC - VicBagger Tarzan Bars, Gus +2 Euroflip, Goody Fork Lowers, Atom Bomb Exhaust, Lloydz Timing Wheel, Adjustable Lowering Link, VicBagger Tips, Kuryakyn ISO Grips, Ricz plate bracket.
Past Rides:
2004 Yamaha Roadstar Warrior
2003 Yamaha V-Star 650
sthxc83 is offline
post #3 of 13 (permalink) Old 06-29-2015, 11:53 PM Thread Starter
deepstuff's Avatar
Should ride on the outer edge of pulley?
post #4 of 13 (permalink) Old 06-30-2015, 09:42 AM Thread Starter
deepstuff's Avatar
Should the belt be riding on the outside edge of the pulley?
post #5 of 13 (permalink) Old 06-30-2015, 10:31 AM Thread Starter
deepstuff's Avatar
My noise is not intrusive, i almost have ti listen for it, but belt is against outside edge of rear pulley.
post #6 of 13 (permalink) Old 06-30-2015, 11:16 AM
LILMAGS500's Avatar
Loosen your axle nut , not a lot but enough so if you tap it lightly it will move . Loosen your left side adjusting nut 1/4 -1/2 a turn , no more than that , tap it forward to bottom out the adjuster and tighten the axle nut . This should help to pull the belt more towards the center of the rear pulley if its riding tightly against the outside . Sometimes your belt is more likely to squeak too if its unusually on the loose side . 1/4 -1/2 is a very small increment but may just do the trick . Clean your belt while your there with a plastic bristle brush and some soapy water , dish detergent is fine .
LILMAGS500 is offline
post #7 of 13 (permalink) Old 06-30-2015, 12:09 PM Thread Starter
deepstuff's Avatar
Can I do that with bike on the ground?
post #8 of 13 (permalink) Old 06-30-2015, 01:03 PM
LILMAGS500's Avatar
Yes , I had to do a full adjustment one time after my dealer overtightened my belt and virtually locked up on me when it heated up .... 60 miles from home . Yours is simple , this is why I told you to tap it forward , use a small piece of wood to put against it and hit it just until it bottoms out , then sock down the axle nut to 60 ft lbs , or in layman's terms , till its tight .
post #9 of 13 (permalink) Old 06-30-2015, 01:06 PM
LILMAGS500's Avatar
And , don't get your finger caught in the belt and cut the end off of it like I did last year .... Actually , today might even be the anniversary of that faithful day .... I did it while spinning the wheel on the lift with the belt guards removed , Don't remove your belt guards !
post #10 of 13 (permalink) Old 07-05-2015, 05:41 AM
ditech's Avatar
I'm not sure the belt will ever be whisper silent. There will always be some type of friction with moving parts to make some noise
ditech is offline
