2012 8-ball problem - Victory Forums - Victory Motorcycle Forum
post #1 of 12 (permalink) Old 06-30-2015, 10:35 AM Thread Starter
Chad782's Avatar
Default 2012 8-ball problem
I have had my Vegas 8-ball for about a month now. I have had about 4 instances where it shuts off on me while I grab the clutch. I hit the start and it fires right back up. Any ideas what might be going on?
2016 Victory Cross Country
2012 Victory Vegas 8-ball (Traded)
2003 Harley Sportster 883 (Traded)
Check me out on YouTube Kaptain Granite I do motovlogs while out on the bike.
Chad782 is offline
post #2 of 12 (permalink) Old 06-30-2015, 10:43 AM
LILMAGS500's Avatar
What if any mods are done to the bike , your pipes are not stock , do you know if you have air intake or fuel controller on the bike , could be a stage one flash from the dealer ... Just need more info from you to help determine potential problems . First thing I would do is check you battery terminals to make sure they are good and tight , when they are loose or your battery is weak Vics can do some funky things ....
LILMAGS500 is offline
post #3 of 12 (permalink) Old 06-30-2015, 10:51 AM Thread Starter
Chad782's Avatar
Stage one pipes other than that no other mods to it. When I did first get the bike I did notice a bit of white powder from one of the spark plugs where it looked like something leaked. No idea if that would have anything to do with it. Maybe it's slightly corroded?
Chad782 is offline
post #4 of 12 (permalink) Old 06-30-2015, 11:03 AM
LILMAGS500's Avatar
Nope , someone used S100 to clean the bike and didn't rinse / blow dry around the plugs good enough . NORMAL .
Check battery connections and disconnect your 02 sensors (this should cause your bike to run a little richer) zip tie the wires neatly out of harms way , and see if this cures the stalling issue . You may need to reset your IAC valve by turning the key to the on position , with the handle bar kill switch in the off position , then cycle the switch on for 15 seconds or so then off for 15 seconds or so, all with the key in the "ON" position , then turn the key off , back on and start the bike normally . During this time you will hear the clicking of the IAC valve while it is resetting .
post #5 of 12 (permalink) Old 06-30-2015, 11:13 AM
are you blipping the throttle
its a NO NO with victories
post #6 of 12 (permalink) Old 06-30-2015, 11:14 AM Thread Starter
Chad782's Avatar
Ok awesome I'll give it a shot later on today. Last time it cut off on me I was about to pull into my driveway. Down shifted to 2nd and as soon as I let the clutch out it cut out which seems like the case for the other times, always after a down shift.
Chad782 is offline
post #7 of 12 (permalink) Old 06-30-2015, 11:18 AM Thread Starter
Chad782's Avatar
No blipping here
Chad782 is offline
post #8 of 12 (permalink) Old 06-30-2015, 11:29 AM
what rpm is the bike at when you let the clutch out.
the rpm should be 2000 at least
post #9 of 12 (permalink) Old 06-30-2015, 11:35 AM Thread Starter
Chad782's Avatar
I always shift around 3000 rpm let out at 2000-2100
Chad782 is offline
post #10 of 12 (permalink) Old 07-01-2015, 08:47 AM Thread Starter
Chad782's Avatar
Going to give the battery lines a look over tomorrow. Rain kinda put a damper on that today. I did the reset like you said then I had to rush home to beat the rain yesterday and it didn't quit on me so that was promising.
Chad782 is offline
