low fuel light ? - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 09-24-2012, 12:35 PM Thread Starter
sonofdob's Avatar
Default low fuel light ?
low fuel light has come on and stays on even though the tank is full...it's an '04 Vegas...any ideas...thanks...
'04 Vegas...far from stock...
sonofdob is offline
post #2 of 6 (permalink) Old 09-24-2012, 12:38 PM
CrossRoads's Avatar
Did you just give it a good wash, or was it just ridden through heavy rain?
If not, you likely have a faulty termistor (fuel pump level sensor).
CrossRoads is offline
post #3 of 6 (permalink) Old 09-24-2012, 12:44 PM Thread Starter
sonofdob's Avatar
nope...just rode the Oyster Run...Vancouver BC to Anacortes WA...200 miles round trip...dry as a bone...the light came on during the ride...
sonofdob is offline
post #4 of 6 (permalink) Old 09-24-2012, 12:51 PM
CrossRoads's Avatar
I suggest running this by the Victory Fuel Pump Master, Rylan Vos (The Vic Shop, Inc - 515-339-4313). I have just sent him a PM also to get his attention to this thread and see if he can shed some more light into your low fuel light issue.
post #5 of 6 (permalink) Old 09-24-2012, 01:03 PM
Vicbuilder's Avatar
The low fuel thermistor wire is probably broken off inside the tank. I've seen that quite a few times. It's probably grouding out which is lighting up the light. You'll have to remove the fuel pump from the tank and either fix or replace the thermister.
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
Vicbuilder is offline
post #6 of 6 (permalink) Old 09-24-2012, 01:16 PM Thread Starter
sonofdob's Avatar
got it...thanks Vicbuilder...
sonofdob is offline
