timing wheel in general. - Victory Forums - Victory Motorcycle Forum
post #1 of 9 (permalink) Old 07-13-2015, 11:11 AM Thread Starter
Question timing wheel in general.
I'm sure the this is a really dumb question , but..
Looking at videos and pictures, it appears that this gear drives the cams. I suppose at 1/2 speed. But I can't see what drives the gear. What am I missing?
swodo is offline
post #2 of 9 (permalink) Old 07-13-2015, 11:45 AM
https://www.youtube.com/watch?v=4zdBSqms7vU
https://www.youtube.com/watch?v=-B6QTTPcNHg
post #3 of 9 (permalink) Old 07-13-2015, 04:13 PM Thread Starter
thanks for the links.They don't show what drives the timing wheel/cams, however.
swodo is offline
post #4 of 9 (permalink) Old 07-13-2015, 04:26 PM
Lostintexas's Avatar
Not exactly sure what you are asking. The timing wheel is on the crank shaft. The crank also turns the chains that operate the cams, which in turn operate the valves. Pistons and such are a part of all the mix and the crank is what they are mounted to. The timing wheel is nothing more than a signal device for the spark.
This is the readers digest version, and the same with any engine that uses chains.
Is this what you were asking?
I ride with the Force.
Lostintexas is offline
post #5 of 9 (permalink) Old 07-13-2015, 04:41 PM Thread Starter
Thanks for the links, they don't show what drives the timing wheel , though. I assume the wheel drives the cam chains. If its keyed to the crankshaft, what are the gear teeth for? Aren't cams usually driven at half the speed of the crank? The LLoyds wheel simply moves the gear teeth forward or back. Unless the teeth are driven by, or drive something, moving the gears relationship to its shaft would do nothing. I just don't get it. Its hard to explain.
swodo is offline
post #6 of 9 (permalink) Old 07-13-2015, 04:46 PM
The timing wheel has a movable "notch" in it that the sensor reads, telling the engine when to fire the spark. The wheel doesn't drive anything, it just spins on the crankshaft spinning by the crank sensor. Picture a normal gear with a missing tooth; that is the notch that the sensor looks for.
post #7 of 9 (permalink) Old 07-13-2015, 05:25 PM Thread Starter
OK, I got it now. It's not a gear.
Thanks to everyone for trying to educate me.
swodo is offline
post #8 of 9 (permalink) Old 07-14-2015, 08:22 AM
Its a speed wheel or reluctor wheel so the sensor can count the teeth and know when to spark
2007 Hammer
S&S Intake
Lloydz Timing Wheel
Victory Stage 1 Drag Pipes
Cincinnati, OH
OhioPatriot308 is offline
post #9 of 9 (permalink) Old 07-14-2015, 09:45 PM
Oldman47's Avatar
It is really simple. The timing wheel is mounted directly on the end of the crankshaft. As it spins its position is read by a reluctor coil. If you examine the OEM timing wheel you will see a "missing" tooth. That missing tooth marks the crankshaft position for the engine control electronics. The variable timing wheel simply moves that gap around so the ECM sees a different crankshaft position than it would see with the OEM wheel. If you are interested in the after market adjustable timing wheel, Rylan Voss of the Vic Shop addresses it here.
https://www.youtube.com/watch?v=t3_RjEdk5ZI
Oldman47 is offline
