Chain rattling noise under load, XCT headed to the shop - Victory Forums - Victory Motorcycle Forum
post #1 of 46 (permalink) Old 07-14-2015, 10:30 AM Thread Starter
Default Chain rattling noise under load, XCT headed to the shop
Rattling noise from engine under acceleration or pulling a hill. Has gotten more pronounced over the last few rides.
MPG is down to 33. Bike is a '12 with cam job and 14k miles. I don't push it hard at all.
Wild a$$ guesses as to what's going on?
Edit: pic of plugs added page 3
MMGUT is offline
post #2 of 46 (permalink) Old 07-14-2015, 11:03 AM
navycraig's Avatar
I'm interested to hear what they tell you.
I feel like I have the exact same issue, but the bike runs like a champ so I have pretty much chalked it up to the idea that these big V-twin engines can't help but to have some noise.
Wearing my half helmet with no music, it really bugs me. With my 3/4 helmet and music I don't hear it so I feel better.
God Bless America
U.S. Navy Retired
2012 Victory Crossroads Classic L.E. (#258)
PC V and Dyno tuned by Kyle of KMC
Lloydz High Flow Filter
Lloydz Timing Wheel
Lloydz Drop In Cams
Lloydz 1/4 Turn Throttle
Crossroads HID high/low lights
Making 113 HP and 115 TQ
navycraig is offline
post #3 of 46 (permalink) Old 07-14-2015, 11:07 AM
rattling I think would refer to something loose.
I'm guessing you have a knock. Probably a piston
post #4 of 46 (permalink) Old 07-14-2015, 11:46 AM
Way to jump to conclusions. You're joking right? A "loose piston" would be pronounced at an idle. MMGUT, i'm not sure what your mechanical expertise is but you are stating under load and going up a hill. This to me sounds like you're describing pinging. If you had something mechanically wrong you should be able to hear it while idling. If in fact you can hear it while idling, buy a stethoscope and try to find the noise. Please keep us updated. Also, is your bike tuned?
2007 Hammer
S&S Intake
Lloydz Timing Wheel
Victory Stage 1 Drag Pipes
Cincinnati, OH
OhioPatriot308 is offline
post #5 of 46 (permalink) Old 07-14-2015, 11:56 AM
BBob is online now
post #6 of 46 (permalink) Old 07-14-2015, 11:57 AM
BP6666VR's Avatar
Subscribed ... It could even be your PCV ... when i installed my PCV and NO autotune .. The bike under load did the same, pinging or ratling sound, then i downloaded different maps & autotune and it was gone
When i installed my cams myself then the bike did not run perfect until i opened the airvalve more and i got a map for cams
It just could be small changes to be made ??
Please update us soonest
Cross Country Tour 2014 [B]
BP6666VR is online now
post #7 of 46 (permalink) Old 07-14-2015, 12:02 PM
skullsessions's Avatar
Sounds like little marbles in the top of the jug...only happens under load?
I'm not a mechanic. But I'm with OhioPatriot. That could be pinging. I've had it before when I run 87 octane, it's hot out, and I'm pulling hard uphill. And as the weather warms up, it might seem to get worse with each ride...because, doesn't pinging get worse as it temps increase?
33 mpg doesn't sound out of line to me if you've got cams and you're pulling hard uphill.
2013 Cross Country (Houston/Katy Texas)
People think I am too patronizing. (That means I treat them as if they're stupid.)
skullsessions is offline
post #8 of 46 (permalink) Old 07-14-2015, 12:31 PM
This could be it too. We don't have enough info to rule it out one way or the other.
BBob is online now
post #9 of 46 (permalink) Old 07-14-2015, 12:34 PM
I certainly wouldn't argue it with you either way. My friends will attest to the fact that I'm NOT a mechanic.
I'm kidding. I don't really have any friends.
post #10 of 46 (permalink) Old 07-14-2015, 12:35 PM Thread Starter
Great responses so far.
Lets confuse things with some more info:
-bike runs very smoothly
- cams were installed before I bought the bike with a PCV included.
- I had the bike dyno tuned here in Utah 3k miles ago which eliminated a dead spot at 2k rpm
- I have been running 88 octane because I live at 4200' elevation and typically ride at 7000'+ because the interwebs said 91 octane isn't needed here
- Last tank I filled with 91 octane but the noise persists, only under load.
Thanks. With help here maybe I can skip the shop visit :-)
MMGUT is offline
