Chamber and dish volume differences between 07 and 08 - Victory Forums - Victory Motorcycle Forum
post #1 of 15 (permalink) Old 07-25-2015, 07:48 PM Thread Starter
rumblebox's Avatar
Default Chamber and dish volume differences between 07 and 08
Could someone post the cylinder dish and combustion chamber volumes for 07 and 08 100 engines so i can determine my exact compression with a simple slug swap..... and so i can determine if it's even worth the time.
Thanks in advance.
2007 Hammer, lowered, Bassani 2:1(updated), torque tubes, Dobeck AFR+.
2000 Firebird Formula, 6.0L, LS3 heads, etc, etc, etc, - SOLD
HM3(FMF) - 3/7 Lima Co. 2010 Helmand, Afghanistan
rumblebox is offline
post #2 of 15 (permalink) Old 07-26-2015, 12:14 PM
write Rylan tell him what you're up to or want to
The Vic Shop
26416 289th Place, Suite F
Adel, IA 50003
[email protected]
515.339.4313
post #3 of 15 (permalink) Old 07-27-2015, 05:58 AM
kevinx's Avatar
It's not the dish in the piston, but the offset of the wrist pin. When used in an 07 the 08 Pistons net you roughly 10.25:1cr. Just under half a point.
kevinx is offline
post #4 of 15 (permalink) Old 07-27-2015, 07:28 AM Thread Starter
rumblebox's Avatar
Do you know their position relative to the deck?
post #5 of 15 (permalink) Old 07-27-2015, 07:34 AM
Motorbikerx's Avatar
think I saw somewhere that milling the base of the cylinders raises compression somewhat.
can't remember where but.
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
post #6 of 15 (permalink) Old 07-27-2015, 08:09 AM Thread Starter
rumblebox's Avatar
Thats true, but depending in the piston height, the quench could be too tight at that point.
Having a tighter quench typically creates more turbulence, thus creating a more efficient burn, which makes more MPG and less potential detonation. If it's to tight though, you risk smacking the head with the piston.
post #7 of 15 (permalink) Old 07-27-2015, 08:51 AM
kevinx's Avatar
Decking the base of an 07 cyl .030 gives you a nice tight quench area, and also makes about a half a point of compression.
Had all the math in a notebook on pin to crown, and cc of the popular heads. Unfortunately when I moved from the dealer to my new shop; that notebook disappeared. Fortunately for me I remember the end results of the math in my little head
kevinx is offline
post #8 of 15 (permalink) Old 07-27-2015, 11:54 AM Thread Starter
rumblebox's Avatar
So if i use 08 pistons AND deck the jugs, will they hit?
post #9 of 15 (permalink) Old 07-27-2015, 01:13 PM
kevinx's Avatar
I've got an 06 out there like that
kevinx is offline
post #10 of 15 (permalink) Old 07-27-2015, 01:19 PM Thread Starter
rumblebox's Avatar
So with the jugs decked .030", which pistons stick above the deck .010", 07 or 08?
the gasket is .022"?
