Engine may be gone - Victory Forums - Victory Motorcycle Forum
post #1 of 18 (permalink) Old 07-26-2015, 02:55 PM Thread Starter
Bat Man's Avatar
Default Engine may be gone
After arriving at work this week I notice my Pin making a lot of racket at idle. It sounds like a chain hitting a piece of tin. Took it home and checked for anything loose. Oil was good. Could not find any exhaust leaks. Plugs looked ok. Placed a rag over each exhaust while it was running and it is defiantly coming from the front cylinder. My first thought was a bad cam tensioner. Found a post about cam tensioner noise. Read a post from Kevin about swapping the cam tensioners to see if the noise moves to the other cylinder. Pulled the front tensioner out, but could not get the tensioner out of the housing. It was moving freely. I did a compression test and got 130 psi on the rear cylinder and 110 on the front. Found another post that ended up being a piston wrist pin retainer, UGH. With the low compression it must be in the cylinder. Does anyone know of anything else I could check before I take it in? I was going to upload a video but cant get my YouTube account to work.
The only mods I have is a stage I flash, Swept pipes with different baffles, the O2ís removed, K&N filter, and IAV. I have a little less than 18K miles.
08 Kingpin 8Ball
Bat Man is offline
post #2 of 18 (permalink) Old 07-26-2015, 03:57 PM
110 compression not good. If your dealer doesn't seem smart enough take it down to Kevinx. If your wallet can afford it you might want to think about cams seeing how they will have the motor out of bike.
Do Not Ride It
post #3 of 18 (permalink) Old 07-26-2015, 04:20 PM
Attachment 146474
Just curious did you have the throttle pinned wide open while doing the compression test with both plugs removed. It often makes a significant difference.
presently owned bikes
1993 HD fxrp
1982 HD Sturgis
2009 Honda rebel
co owner
Joe_ is offline
post #4 of 18 (permalink) Old 07-26-2015, 05:18 PM Thread Starter
Bat Man's Avatar
No, I forgot about opening the throttle. I'll check it again. Not sure what are good #'s. I was thinking up towards 150 is that right?
Thanks
08 Kingpin 8Ball
Bat Man is offline
post #5 of 18 (permalink) Old 07-26-2015, 05:45 PM Thread Starter
Bat Man's Avatar
This time I got 190 on the front cylinder and 180 on the rear. That makes me feel a lot better, but I'm not sure where to go from here.
Maybe I need to take another look at the cam tensoiner?
08 Kingpin 8Ball
Bat Man is offline
post #6 of 18 (permalink) Old 07-26-2015, 07:24 PM Thread Starter
Bat Man's Avatar
Here is a sound clip
08 Kingpin 8Ball
Bat Man is offline
post #7 of 18 (permalink) Old 07-26-2015, 08:08 PM
The video is coming up as private. You have to go into the video settings (at www.youtube.com) and change to Public or Unlisted
post #8 of 18 (permalink) Old 07-26-2015, 08:31 PM
kevinx's Avatar
Does the noise go away when you pull in the clutch? Seriously doubt you damaged the engine.
kevinx is offline
post #9 of 18 (permalink) Old 07-26-2015, 09:16 PM Thread Starter
Bat Man's Avatar
Broggyr
Try again I did not hit publish.
kevinx Does the noise go away when you pull in the clutch?
No It sounds the same with the clutch in.
08 Kingpin 8Ball
Bat Man is offline
post #10 of 18 (permalink) Old 07-26-2015, 09:46 PM
Wonder if it's a bad cam chain tensioner. Could that be the cam chain slapping around in there?
