Speedometer fail and rough running - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 07-26-2015, 03:09 PM Thread Starter
Default Speedometer fail and rough running
2010 UK spec (106/6 speed) Vegas 8-ball with tach kit installed.
Speedo stopped working and getting a noticable burble and pop on deceleration (more than the 'normal' amount).
One time the speedo worked for duration that ignition was turned on and the burble/pop stopped. After that it did not work again and the burble was back.
Checked all connections in headlight. Speedo lights up and odometer is showing a number but it does not change.
Checked the sensor on the back of crankcase. No corrosion and it looks fine, bathed in oil internally. Sprayed plug with contact cleaner.. no help.
Any ideas what else it could be people?
A local motorcycle garage is going to buy a plug for the computer reader (I have to pay half of the cost), but still easier than my local dealer, who is two hours away and cannot check the bike until well in to August
Any advice would be welcome. The combination of the two issues together is so weird!
Thanks!
J.
ukflyer is offline
post #2 of 6 (permalink) Old 07-26-2015, 03:51 PM
unhook the speedo all together and see if the pop goes away.
The speed-o should have nothing to do with the pop
post #3 of 6 (permalink) Old 07-26-2015, 05:25 PM
NOEMTZ's Avatar
Battery connections or bad ground.
www.noemtz.com
NOEMTZ is offline
post #4 of 6 (permalink) Old 07-27-2015, 06:22 AM Thread Starter
Ok. I will check battery connections, although bike starts fine. Where would the ground be bad? Any particular places to check?
ukflyer is offline
post #5 of 6 (permalink) Old 07-27-2015, 06:35 AM
NOEMTZ's Avatar
Been a while, lemme see if I remember correctly on Vegas. Last one I worked on the grounds were lower front portion of engine and behind battery box. Check voltage regulator as well as failing regulators or bad connections at it give same symptoms.
www.noemtz.com
NOEMTZ is offline
post #6 of 6 (permalink) Old 07-27-2015, 07:56 AM
Motorbikerx's Avatar
I think if your local garage tries to plug into the Victorys computer system it could create damage ??...Only dealers with digital wrench can plug into your bike...........I think...right or wrong please???
Victory Vegas 2010
Lloydz 109"cube big bore
" " 495 cams
" " TorqueTubes
" " timing wheel @4 deg.
" " Primary plate
" " IAV
RPW Slash pipes
Progressive 465 rear shock
Kingpin USD Forks
18" XC front wheel
1 3/4" 'Burleigh Bars'
Stebel air horn
12.106 @110.90mph
114/123
Lloyds air filter
" " VM1 Cams
Home gutted exhaust
Maximus
110/116
Gold Coast
Australia
Motorbikerx is offline
