Speed sensor wire and gear advance mapping for PCV - Victory Forums - Victory Motorcycle Forum
post #1 of 7 (permalink) Old 07-26-2015, 08:48 PM Thread Starter
jcfz6r1's Avatar
Default Speed sensor wire and gear advance mapping for PCV
I've been looking around for info on where the speed sensor wire is for a 2015 Vegas, but haven't come up with anything good yet.
Anyone know? I'm trying to setup gear advance mapping on the PCV w/AT. I've used this with good results on a few other bikes and wanted to give it a shot on the Vic as well.
Anyone have this hooked up already?
The next trick is going to be getting a jack to keep the tire elevated to calibrate the speed/gears...
2015 Vegas 8-Ball:
Lloydz Adj. TG +4deg
Lloydz TT Intake
PCV + Autotune
RPW Big Slash
Other bits and pieces...
jcfz6r1 is offline
post #2 of 7 (permalink) Old 07-27-2015, 05:55 AM
kevinx's Avatar
The speed sensor is on the top of the case behind the rear cyl. That said you don't need to hook anything to the sensor to do a gear advanced map in a PCV.
kevinx is offline
post #3 of 7 (permalink) Old 07-27-2015, 07:14 AM Thread Starter
jcfz6r1's Avatar
Thanks for the info. You're right, I'm not planning on doing anything with the sensor, I just need the wire to tap into for the speed signal. You wouldn't happen to have a good location to tap the wire / a picture of where you tapped it would you?
2015 Vegas 8-Ball:
Lloydz TT Intake
PCV + Autotune
RPW Big Slash
jcfz6r1 is offline
post #4 of 7 (permalink) Old 07-27-2015, 08:52 AM
kevinx's Avatar
lol I just use my dyno
kevinx is offline
post #5 of 7 (permalink) Old 07-27-2015, 10:05 AM Thread Starter
jcfz6r1's Avatar
well that's great to see the speeds but somehow the PCV needs to know the speed/rpm to determine the gear and change the map, that's what I'm looking for. To give it the speed signal.
How are you doing gear advanced mapping without adding that connection to the PCV?
2015 Vegas 8-Ball:
Lloydz TT Intake
PCV + Autotune
RPW Big Slash
jcfz6r1 is offline
post #6 of 7 (permalink) Old 07-27-2015, 10:25 AM
kevinx's Avatar
Just plug it in, and hit enter.
kevinx is offline
post #7 of 7 (permalink) Old 07-27-2015, 01:24 PM Thread Starter
jcfz6r1's Avatar
Thanks I'll try that...
In the meantime, I think I found it. Should be pin 42 on the ECM and a Dark Green/Brown wire.
2015 Vegas 8-Ball:
Lloydz TT Intake
PCV + Autotune
RPW Big Slash
jcfz6r1 is offline
