Help With Cam Tensioner - Victory Forums - Victory Motorcycle Forum
post #1 of 4 (permalink) Old 07-30-2015, 09:01 PM Thread Starter
Pheonix's Avatar
Default Help With Cam Tensioner
Front jug has an unusual mechanical noise at start up on my 2011 Kingpin and every once and a while at idle. I'm thinking it the cam tensioner. I know they don't usualy go bad but several have so I figure I'll change it. Got new one in and took old one out. Now the question.... How do I get the hydraulic tensioner out of the body of the cap that screws into the jug? Spins freely, but will not pull out.....
2011 Kingpin - Scarlett
Stage I Pipes with Thunder Monsters & NO Catcons
Ness Laydown Plate Holder with Custom Dynamics LED Plate Frame
Custom Ness Engine Covers
V92C Floorboards with NON-LOW Mounts
Ness Ram-Air
PC-V
Lloydz Timing Wheel
Dyno Tuned by 804 Motor Sports
97.26 HP / 110.42 # for now...
Pheonix is offline
post #2 of 4 (permalink) Old 07-30-2015, 09:12 PM
kevinx's Avatar
It's just in there with suction from the oil. A quick hit of air in the feed hole will pop it out
kevinx is offline
post #3 of 4 (permalink) Old 07-31-2015, 01:28 AM
Mine had a thin clip ring around the pin on the inside. Just put the shaft in a vice and yank on the cap. It will pop out
Geis325i is offline
post #4 of 4 (permalink) Old 07-31-2015, 10:11 AM Thread Starter
Pheonix's Avatar
Air did the trick. Was still in there pretty good. Thanks!
Ness Ram-Air
PC-V
Lloydz Timing Wheel
Pheonix is offline
