Dangerous Issue - Please help! - Victory Forums - Victory Motorcycle Forum
post #1 of 19 (permalink) Old 10-09-2012, 12:47 PM Thread Starter
Roughrider's Avatar
Default Dangerous Issue - Please help!
2011 Cross Country. 39,000 miles. Last modification was the addition of HID kit (High and Low), about a month or two ago. Have not ridden the bike since Thursday, last. All the usual things happen when I turn the key to the on position. But only heard a clicking sound when I pressed on the start button. Turned key off and tried three times, fourth time motor kicked over started. Got about two blocks away and my low beam headlight went out. Pulled the clutch in and also noticed that the battery readout showed the needle pegged at the top (18)? The needled went down and the headlight came back on? Continued to ride and after a mile the headlight went out, battery needle pegged at top, and an engine light came on. Turned on the Hazard lights, so that I could warn others, but those ceased working after a few minuets. Then I turned the left turn signal on, and it also stopped working after a few minutes? Went another mile, same problem all the way home but without engine light showing. Really strange part is, when I turn the High Beam on, the battery needle stayed between 14 and 12, lights never went off?
Does anyone know what the hell is going on? I am leaving work early, so that I can get home and try to figure this out. Will periodically check this site
Stay Safe and Live long,
Roughrider
2011 Cross Country
Roughrider is offline
post #2 of 19 (permalink) Old 10-09-2012, 01:01 PM
Check your battery cables. Make sure they are tight.
Sent from my iPhone using Motorcycle
miniski is offline
post #3 of 19 (permalink) Old 10-09-2012, 01:04 PM
CrossRoads's Avatar
Most likely you need a new voltage regulator. See if the area underneath the chin of the bike smells like sulfur - if it does, the voltage regulator is on its way out. Don't ride with a bad voltage regulator as it will ruin the battery, if it has not already.
CrossRoads is offline
post #4 of 19 (permalink) Old 10-09-2012, 01:04 PM
kevinx's Avatar
Weak battery or bad connection wreaking havoc with the voltage regulator.
kevinx is offline
post #5 of 19 (permalink) Old 10-09-2012, 01:04 PM
beast30's Avatar
First off i would try just disconnecting the hid set up and try that..at least to eliminate if that is the problem. Other then that possibily a voltage regulator that is going out.. throwing to much voltage out and messing up the computer??? Not sure why it wouldnt want to start on your first couple tries though? One more thing check your battery cables for secure connection...might even be a battery issue.
Sent from my DROID RAZR using Motorcycle.com Free App
2012 XC Imperial Blue/Blacked out, LLoyds filter, LLoyds timing wheel,
VM1 DR cams, PC5, LLoyds ECM, Big Gonzo, KM meat hook bars (internally wired), Conquest underdrive pulley, KM instrument bezels, JTD lowers with speakers, PBR300 amp with Polk 6.5, .40 cal cheese wedges, tinted turn and tail
beast30 is offline
post #6 of 19 (permalink) Old 10-09-2012, 01:05 PM Thread Starter
Roughrider's Avatar
Default Thank you!
miniski,
Will be getting home about 2:30. That is on my list of things to check. Riding for thousand of miles and have never experienced or heard of this issue before?
Thank you!
Roughrider
2011 Cross Country
post #7 of 19 (permalink) Old 10-09-2012, 01:09 PM Thread Starter
Roughrider's Avatar
Default Friends I never met!
All,
Trust and depend on good people like you to share your knowledge without hesitation.
Thank you for the suggestions and quick replies.
God Bless!
Roughrider
2011 Cross Country
post #8 of 19 (permalink) Old 10-09-2012, 01:18 PM
lunaticrider's Avatar
Like Kevin X said low battery can make a motorcycle do some stupid shit, Hid's spike on start up but for only about 7 seconds or so. I've seen batteries that look good and test good but are actually the culprit for many issues....
Sent from Hell....
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
post #9 of 19 (permalink) Old 10-09-2012, 01:23 PM
kevinx's Avatar
My answer was not a guess. This reaction is typical of a Vic starting with low voltage or open circuit in or to[cable] battery. The problem is either a loose connection of the terminal or a battery with an internal bad connection between two plates. Again...This is not a guess
kevinx is offline
post #10 of 19 (permalink) Old 10-09-2012, 01:55 PM
That's kind of funny. On Another forum I responded to his post with:
Based on what you desccribe and a quick look in the 2012 XC service manual, I'd guess regulator. I recomend you download the 2011 service manual. If you're handy with a digital multi meter and following instructions, you can test the system. Simply TOO MUCH info. and flow charts to walk through it in a forum. A REAL mechanic (That Would NOT Be Me) may be able and willing to break it down. I have to go step by step, A-Z to get it right.
It would seem I skipped step A!
Then I read the intro to troubleshooting the charging system again and realized that right there in Black and White it states:
NOTICE: The battery must be fully charged and in good condition to obtain accurate readings.
It then goes into the flow chart. Me being simple, I'd start with the battery as Kevin says. He does do this for a living and has a handle on all the little quirks of our machines.
Riding a 2012 Imperial Blue Cross Country
Creek_IP is offline
