4.6" gas tank plug removal and re install (05'Hammer) - Victory Forums - Victory Motorcycle Forum
post #1 of 2 (permalink) Old 10-11-2012, 10:56 PM Thread Starter
Default 4.6" gas tank plug removal and re install (05'Hammer)
can anyone on here tell me why this plug is even there? what is the practical purpose of it? i tore both o-rings re installing it. is there any reason why i can cut a piece of steel and weld the hole closed?
05' Hammer
Lamborghini Grey/Semi Flat clear
LED turns
Slasher pipes
Avon cobras F/R
GRAND RAPIDS, MN
faslane is offline
post #2 of 2 (permalink) Old 10-12-2012, 09:44 AM
Vicbuilder's Avatar
1) the plug is access to your fuel pump - you'd be permanently sealing it in.
2) The heat of welding would ruin the liner inside the tank.
A helpful hint: Use liberal amounts of grease when installing this plug. Sometimes I grease both the tank and the plug/o-rings, then spray wd-40 over the grease. The plug will fall into place with your pinky finger using this method.
Rylan Vos
The Vic Shop, Inc
(515)-339-4313
Vicbuilder is offline
