ReProgrammin Trunk running lights - Victory Forums - Victory Motorcycle Forum
post #1 of 6 (permalink) Old 08-09-2015, 06:18 PM Thread Starter
Default ReProgrammin Trunk running lights
Ok,
I just bought a used 2013 Vision. The person I bought it from stated that he had the dealer change the function of the trunk running lights, into turn signal indicators.
I would like to change these to brake lights. Two questions:
1) Is this functionality possible?
2) If yes above, how to do it.
Thanks for any help.
z4racer is offline
post #2 of 6 (permalink) Old 08-09-2015, 08:28 PM
eotsis1's Avatar
https://www.mediafire.com/folder/aoq...ictory_Manuals
check here for your bike and scroll to wiring diagram
1 Corinthians 15:57 But thanks be to God! He gives us the victory through our Lord Jesus Christ.
2009 Vision... Lloyd cams, pipes, timing wheel +4, power commander V, gps, xm, centramatics, DARKSIDE
eotsis1 is offline
post #3 of 6 (permalink) Old 08-10-2015, 10:47 AM Thread Starter
Thanks for the link to the download. I have downloaded the file and reviewed chp. 19 electric but did not see anything that would help re-programming the trunk light functions.
I will continue to review and search.
z4racer is offline
post #4 of 6 (permalink) Old 08-10-2015, 10:58 AM
first you have to figure out how its wired now. Then you have to pull it apart and see if there is dual or single filament bulbs
post #5 of 6 (permalink) Old 08-10-2015, 11:15 AM Thread Starter
Got ya. I was assuming(we all know what that means) that is was programmed via a special sequence in the ECM. Know that I know it is a physical wiring/bulb item I can probably figure it out.
Thanks
z4racer is offline
post #6 of 6 (permalink) Old 08-10-2015, 04:00 PM
eotsis1's Avatar
there are six bulbs.
top two are run/brake/ turn.
mid two are run / brake only or turn only. they both turn off if braking and turn is on.
bottom two are run/ brake
eotsis1 is offline
