XRC Will Not Start in Gear - Victory Forums - Victory Motorcycle Forum
 6Likes
post #1 of 36 (permalink) Old 08-27-2015, 10:21 PM Thread Starter
Mid TN Rider's Avatar
Default XRC Will Not Start in Gear
My bike will not start in gear with the clutch pulled. I verified that the micro switch is changing state with a pull on the clutch lever.
Has anyone experienced this or have any ideas on how to fix this condition?
Mid TN Rider is offline
post #2 of 36 (permalink) Old 08-27-2015, 10:28 PM
Check your homo phobic modulator,might have a short in it.
TN Black Hammer is offline
post #3 of 36 (permalink) Old 08-28-2015, 12:48 AM
post #4 of 36 (permalink) Old 08-28-2015, 07:29 AM
soofle616's Avatar
It has to be the switch, a connection issue, or the wiring.
Since the bikes don't have a sidestand switch, the only other logical source of the problem is the clutch switch. If you're sure it's functioning properly then there has to be a bad connection somewhere. Check for loose connectors, corroded pins, or broken wires.
2013 Cross Roads LE
I'm on the app store! Check out Solitaire: Slide it's free!
soofle616 is offline
post #5 of 36 (permalink) Old 08-28-2015, 07:54 AM
I had the same problem and it was entirely my fault. I changed from cable to hydraulic for the clutch and it comes with an entire lever/master cylinder ass'y. I swapped out the lever and controls easily enough, but forgot to plug in the clutch switch
post #6 of 36 (permalink) Old 08-28-2015, 09:43 AM
Pull the switch wires off and jump across them. If it starts in gear now, it is the switch. If it still does not start it is in the wiring. Had the same thing on my Kingpin. Turned out the switch was good, but the arm was not moving enough to activate it. Let us know what you find.
Gdfishwell Galveston,Tx 2008 Kingpin Tour Lloyd's timing wheel set at +3degrees, kuryakyn isogrips, kuryakyn throttle lock with matching left side bar end weight
gdfishwell is offline
post #7 of 36 (permalink) Old 08-28-2015, 11:03 AM
sure would of been nice if you said what year and model
post #8 of 36 (permalink) Old 08-28-2015, 11:07 AM
He did say XRC in the title of the first post, so I assume Cross Roads Classic.
post #9 of 36 (permalink) Old 08-28-2015, 11:10 AM Thread Starter
Default Model
I dont understand why my signature is not showing in my posts. It is showing in my CP. I am riding a 13 Crossroads Classic
2013 XR
PCV, AT
Lloydz High Flow Air Filter
Lloydz Timing Wheel
Victory Passenger Backrest
2014 Silverado 1500 LTZ
2015 Acura MDX SHAWD
post #10 of 36 (permalink) Old 08-28-2015, 11:13 AM Thread Starter
The only thing i can figure is that i sent my initial post from my IPhone and the sig didn't show up but it just did when i replied from my Mac Book
2013 XR
PCV, AT
Lloydz Timing Wheel
