Torque Tube filter cleaning help - Victory Forums - Victory Motorcycle Forum
post #1 of 14 (permalink) Old 01-29-2013, 05:44 PM Thread Starter
New Member
Default Torque Tube filter cleaning help
Has anyone removed the filters from the torque tubes to clean them? I can't figure out how to get them off. I loosened the clamps but they won't budge. I don't wanna break anything trying to force them.
Robb
TrashmanNYC is offline
post #2 of 14 (permalink) Old 01-29-2013, 06:46 PM
gibson's Avatar
2012 Fireball Jackpot
gibson is offline
post #3 of 14 (permalink) Old 01-29-2013, 06:53 PM Thread Starter
New Member
Originally Posted by gibson View Post
Doesn't show how to get them off.
post #4 of 14 (permalink) Old 01-29-2013, 07:15 PM
woodrow731's Avatar
Take a set of channel locks and grab it where the filter sets on the intake. You should not have to squeeze the hell out of it. If you have ever changed out a radiator hose you have probably had this problem.
2010 vegas 8-ball
1 1/2 lowering kit
torque tubes,pc-v
vic performance pipe
109 big bore
s&s .495 cams
variable clutch
woodrow731 is offline
post #5 of 14 (permalink) Old 01-29-2013, 07:35 PM Thread Starter
New Member
Kinda tight quarters in there.
post #6 of 14 (permalink) Old 01-29-2013, 08:00 PM
woodrow731's Avatar
I don't know about the jackpot but on the Vegas you can get to the one on the left side. If you get it off it should open up enough room to get to the other one.
2010 vegas 8-ball
1 1/2 lowering kit
torque tubes,pc-v
109 big bore
s&s .495 cams
variable clutch
post #7 of 14 (permalink) Old 01-29-2013, 08:01 PM Thread Starter
New Member
Thanks. I'll check it out tomorrow.
post #8 of 14 (permalink) Old 01-30-2013, 09:05 AM
half_crazy's Avatar
Piece of cake, I've done it several times. Loosen the clamps, give a little twist, they come right off.
2006 Victory Kingpin
half_crazy is offline
post #9 of 14 (permalink) Old 01-30-2013, 09:27 AM Thread Starter
New Member
By hand?
post #10 of 14 (permalink) Old 01-30-2013, 11:25 AM
woodrow731's Avatar
I figured you had already tried to us your hands. If not I would definitely try that first.
2010 vegas 8-ball
1 1/2 lowering kit
torque tubes,pc-v
109 big bore
s&s .495 cams
variable clutch
