stopping power - Victory Forums - Victory Motorcycle Forum
post #1 of 17 (permalink) Old 02-05-2013, 12:18 PM Thread Starter
Default stopping power
had this in the wrong place was told to move it here.
i have the judge and would love to put the hammer front end on there with the double brakes and inverted shocks. dose anyone know if i can just swap the fork tubes over or the whole front end? ive also thought about a sportbike swap from a R1 or Busa. any help would be great
_Chris
SANDS is offline
post #2 of 17 (permalink) Old 02-05-2013, 12:30 PM
so-crates's Avatar
_Chris
Well, you cant just swap fork tubes - the Judge has regular forks, the Hammer has inverted forks. You couldnt just swap them either - you would have to remove the entire front end, including the triple trees, from a Hammer in order to get the fork uppers to fit in the triple trees.
I wouldnt know if that would work though... And checking part numbers wont help.
2003 Vegas - straight pipes, Big Sucker air filter kit, black powder coated everything - foot controls, handlebars, clutch and brake housing, fork lowers, luggage rack, wheels, digital speedo with powder coated housing. Relocated key switch, red plug wires. Mustang solo seat. LED ring blinkers in front. Black DEI pipe wrap.
so-crates is offline
post #3 of 17 (permalink) Old 02-05-2013, 12:48 PM Thread Starter
ya that would be to easy
SANDS is offline
post #4 of 17 (permalink) Old 05-30-2013, 01:05 PM
_Chris
Hows it going sands, any updates on your front end swap?
2010 Vegas 8 Ball
VM1 cams, TTI, IAV, PCV, Timing wheel, RPW Thor
glassback is offline
post #5 of 17 (permalink) Old 05-30-2013, 01:36 PM
half_crazy's Avatar
Realistically, the limit of stopping power is traction available at the front tire. If your front brake will lock the front wheel you have all the brakes you can use.
The advantage to dual discs up front is resistance to heat fade. If you did repeated stops from speed the single disc would get hot and fade long before the dual discs would.
My bike is single disc. It wears EBC Pro-Lite rotors and EBC sintered (HH) brake pads front and rear. I have never faded the brakes on this bike and it stops with authority. Then again, I'm a very timid flower-sniffing kind of rider
2006 Victory Kingpin
half_crazy is offline
post #6 of 17 (permalink) Old 05-30-2013, 01:53 PM
CrossRoads's Avatar
Originally Posted by half_crazy View Post
... the limit of stopping power is traction available at the front tire.
That's correct. If someone wants more stopping power, they should look at upgrading their tires before anything else.
Going down a long downgrade is a great opportunity to cook the brakes if relied upon for maintaining a lower speed. Continuous, light brake application is not only going to wear the brakes faster, but it will overheat them as well. This is why it's always a good idea to use engine brake for slowing down, and use the brakes only if brakes are needed to stop.
I assume everyone knows this, but my assumption is often times proven wrong whenever I see someone lightly riding the brakes on a long downhill slope.
... I'm a very timid flower-sniffing kind of rider
Outta the way, grandma!
CrossRoads is offline
post #7 of 17 (permalink) Old 05-30-2013, 02:09 PM
Squatch's Avatar
To upgrade stopping power ( Ability) you have to do more than just tires.... tires, Brakes, Rotors... lines... Master Cylinder,
As to teh Flower sniffing rider... your right fade resistance is gained with dual rotors... one can generate enough heat on the twisties over using the brakes and end up with some real bad brake fade...
Smart driving and knowning ones capabilities is the key.
Squatch
USN/USCG Vet
2013 Cross Country Tour
Zumo 665 w/weather
Power Commander V
Lloydz Air filter
PTS set to +6*
Hydraulic Clutch
D&D wrapped/RPW baffles
Touring Cams
124 hp/119#ft
A country that forgets it's defenders, will itself soon be forgotten
Squatch is offline
post #8 of 17 (permalink) Old 05-30-2013, 06:57 PM
half_crazy's Avatar
Brakes are over-rated. Who uses the brakes in the twisties?
post #9 of 17 (permalink) Old 05-30-2013, 08:56 PM
lunaticrider's Avatar
Agreed!
2012 Hammer 8 Ball - All upgrades are listed in my Garage
If racing was outlawed ... Then only outlaws would race ...
lunaticrider is offline
post #10 of 17 (permalink) Old 05-31-2013, 04:24 AM
half_crazy's Avatar
Originally Posted by lunaticrider View Post
Agreed!
Your Hammer 8-Ball is single disc... have you ever faded the brakes on it?
If you are going as fast as you can down the straights, braking hard for the corners, and riding like your lap times are being recorded... yes, you will get the brakes hot (you will also get yourself tired in a hurry). But most of us set a speed that we cruise at and only scrub off a little speed for curves. Riding in this way you will drop a gear and maybe trail-brake a little setting up for curves but rarely even touch the front brake.
Now... the inverted front end? EXCELLENT!!! I'm sure I don't have to tell you... but MAN is that nice.
