Throttle Body Cleaning for X-Bikes - Victory Forums - Victory Motorcycle Forum
post #1 of 16 (permalink) Old 02-07-2013, 10:50 AM Thread Starter
BeoBob's Avatar
Default Throttle Body Cleaning for X-Bikes
How the heck do you clean the throttle body on the X bikes. Previous bikes have been fairly straight forward… take off air cleaner / clean intake with cleaner, toothbrush, and rag / start bike, let idle, spray small amounts of cleaner into intake / change plugs and clean air filter.
I have been unable to do this as I normally would. I can’t even get to the throttle body, or even run the bike with the air box exposed.
Soo… what’s the procedure??
2013 Cross Country Tour: Custom paint, stage 1 exhaust, Lloydz Hi-Flow air filter, cams (HOH-VM1-DR), timing gear (HOH-PTS), Power Commander V, Auto Tune module, Gustafson flip shield, OEM passenger backrest with Cycle Ops luggage rack, Vic HID, heel shifter, Rockford amp, Infinity speakers all around.
2011 Cross Country: Burnt and Traded
BeoBob is offline
post #2 of 16 (permalink) Old 02-07-2013, 10:58 AM
i think i saw somewhere they don't have to be cleaned.
now , 2011 crossroads and 05 sportster bobber in the making
in order of ownership, sears compact scooter, honda 305 scrambler, honda 160 dream , triumph 500 trophy trail, honda cb450, sportster, honda f750, 2nd sportster, harley flh, harley super glide, 3rd sportster, bmw k1000, harley low rider, 2nd harley super glide, harley heratage, harley road king, bmw r1150rt,
thats just the street bikes!
ridealittle is offline
post #3 of 16 (permalink) Old 02-07-2013, 11:04 AM
CrossRoads's Avatar
That's correct. No need to clean throttle bodies on the Cross bikes. And less time cleaning and maintaining means more time to ride.
CrossRoads is offline
post #4 of 16 (permalink) Old 02-07-2013, 01:00 PM Thread Starter
BeoBob's Avatar
Sorry, but I’m not buying it.
My bike started idling a little rougher than normal a few months ago, especially when the engine was cold. Last time this happened I found a badly corroded spark plug wire. So the first thing I did was check all the connections associated with the spark plugs and coil. Everything looked good, so I ran some Seafoam through the tank (2X), changed the air filter to the new Loydz filter, changed the plugs, and looked for any loose hoses or electrical connectors while I had the tank off. I also tried to figure out how to get to the throttle body without major disassembly. I didn’t find anything out of place, nor could I figure out how to clean anything. Despite the tune-up there was no improvement. More power, yes. More intake noise, yes. Better throttle response, yes. Smoother idle, no.
The problem has continued to get worse, and your comments have me concerned. Any engine that breathes in fumes off the crankcase will need periodic cleaning of the throttle body to remove deposits. I can see no way around this. The oil mist builds up as gunk around the butterflies and in idle passages. Eventually air just doesn’t flow like it should at low RPMs and you get a rough idle. Every engine that I have owned has run better after a good throttle body cleaning. The more miles between cleanings the more dramatic the improvement. At 23,000 miles this throttle body probably needs a good cleaning regardless of what the book says.
Maybe I have a screw loose here... please someone explain to me the flaw in my logic.
BeoBob is offline
post #5 of 16 (permalink) Old 02-07-2013, 02:12 PM
CrossRoads's Avatar
You have to. It's free!
A redesign took place when they moved from the open loop to closed loop, and as a result, bikes from 2008 and newer no longer need throttle bodies cleaned. So, simple to remember rule of thumb is: if your Victory's 2000-2007, clean the throttle bodies every 5,000 miles. If your Victory is 2008 and newer, don't worry about the throttle bodies. You just might have a vacuum leak.
post #6 of 16 (permalink) Old 02-07-2013, 02:15 PM
you need a meter to check spark plug wires
put a Little dielectric grease on both ends maybe even new spark plugs if let the bike idle a lot
yes bikes before 07 you would half to clean bodys not now unless you have vacum leak. Spray some wd40 up around efi to see if you do
post #7 of 16 (permalink) Old 02-07-2013, 06:37 PM
wspollack's Avatar
I hope I don't sound like the dope I may be, but how about just dumping some Techron (or similar), per label directions, in the gas tank, once a year or so?
Cheers,
Bill P.
wspollack is offline
post #8 of 16 (permalink) Old 02-07-2013, 07:00 PM Thread Starter
BeoBob's Avatar
Sea foam is about the same thing.
There is oil under the frame near the rebreath hoses.
BeoBob is offline
post #9 of 16 (permalink) Old 02-07-2013, 07:06 PM
CrossRoads's Avatar
Why not visit KevinX, at POG? There's no way he doesn't have your rough idle figured out on the spot. And ask him about throttle bodies cleaning when you're there. He will tell you the same thing.
post #10 of 16 (permalink) Old 02-07-2013, 07:18 PM Thread Starter
BeoBob's Avatar
I will if I have too. He's 1.5 hrs away. Trip there, hang out while he waves his magic wand, ride back... and my Saturday is gone. It's a nice ride but my weekends are packed and stacked.
BeoBob is offline
