06 8 ball idle issue - Victory Forums - Victory Motorcycle Forum
post #1 of 23 (permalink) Old 02-11-2013, 10:58 PM Thread Starter
Default 06 8 ball idle issue
At the start of last riding season Everynow and then after riding & warming up the engine, it will sound like its missing or running on one cylinder. It mostly happens at stop lights, and the check engine light comes on when it happens. Revving the engine keeps it from stalling out but it'll also happen when starting to take off, becoming real jerky until it recovers. Also, from time to time the fuel pump will run constantly after starting the bike & not just for the 3 or 5 seconds like usual.
At the beginning of last year I cleaned the throttle bodies, and changed the plugs, as well as tried the throttle body cleaner to test for vacuum leaks. None of this has solved the issue. I've gone through and checked all electrical connections on the bike to make sure their tight / connected. The battery connections are all tight and the battery is reading normal. Any suggestions on what check or try next?
damage04 is offline
post #2 of 23 (permalink) Old 02-12-2013, 12:59 PM
You say battery read right but what you need is load test on it. If its the one that came with it in 06 I'm sure its do for retirement. Battery store and auto parts stores can do that for you.
OK cleaning has been done so look to see if you bumped something and go back and check for vacuum leak. One bike is warm would be the best time.
You say you hear the full pump running all the time. Not sure what you mean there. Check all your electrical connection add a little dielectric grease to them
Go slow and look twice
post #3 of 23 (permalink) Old 02-12-2013, 02:38 PM
depot picker's Avatar
Sounds like an injector is not operating properly.
depot picker is offline
post #4 of 23 (permalink) Old 02-12-2013, 03:12 PM
Tims_04V92TC's Avatar
+1 = Last time you ran SEAFOAM or something similar through the system? Have you left untreated gas stored in the tank? Ehtanol is a KILLER in a fuel system when left standing introducing moisture hence the above point.
Have you checked or replaced the fuel line for obstructions or kinks? Disconnect the fuel line and see if your getting debris out of it like hose rot.
VJ is right, you need a load test on the Battery in addition to ensuring contacts are clean. Weak batt could cause headaches at idle for ECU.
Plug wires / Idle set. Wires may look good but another rider just resolved similar problem by replacing wires and ensuring idle 1000 +/- 50.
Fuel pump pressure, I believe should be 49PSI. Need to check that but the flip side of that if no obstruction in the line is when is this caution coming on? When the pump continues to run past the 3-5 seconds. Just for clarificaiton, your saying when you turn it on the pump continues to run past 5 seconds prior to starting then you continue to hear it?
If you must, remove the tank, open it up and inspect the filter and fuel return line on the pump.
I would start with battery load test and seafoam while your finding a pressure guage to check your fuel pressure.
IBA Rider
Retired Navy SCPO
Chesapeake Va
Tims_04V92TC is offline
post #5 of 23 (permalink) Old 02-12-2013, 10:54 PM Thread Starter
Well, I may of found my issue. When reading a tech article from Lloyd today, I read that the spark plug wires snap onto the plugs VERY HARD. While reading that I remembered thinking to myself that the plug wires came off the plugs quite easily last night when I was pulling my plugs to check them. I think I may not of been getting good spark transfer.
I'm going to take my battery in tomorrow to have it load tested & I double checked the voltages tonight, 12.4 bike off, 14.4 idling. I also plan on taking off my tank tomorrow to clean the injectors again and get a better look at everything else. I'll be checking my fuel line for cracks / dry rot. I'm also going to put new exhaust gaskets on to make sure I don't have an exhaust leak. I'll hopefully have it back together in a week or so to take it for a test ride, then it'll be time to tear down the front end for a shock seal replacement & add ape hangers .
Here is the article from Lloyd, it's a good read: http://www.cross-riders.com/articles...e=11077&fid=40
damage04 is offline
post #6 of 23 (permalink) Old 02-13-2013, 01:04 PM
gibson's Avatar
this is a handy tool to invest in. Will pay for itself in the years to come.plug.jpg
2012 Fireball Jackpot
gibson is offline
post #7 of 23 (permalink) Old 05-13-2013, 11:42 AM Thread Starter
Well the issue continues to happen. It turns out it wasn't a loose spark plug boot after all. I took the battery in And had it tested, it came back good. I've also tested charging system with volt meter while bike is running, everything reads normal there. I'm not sure what else to try here. Throttle bodies are spotless, plugs are new, plug wires are tight and good w/ no holes or leaking spark. I tested for vacuum leaks and found none. I checked every electrical connection I could get my hands on and checked all rubber hoses for cracks. I'm completely stumped. Any other ideas?
damage04 is offline
post #8 of 23 (permalink) Old 05-13-2013, 01:17 PM
Reset TPS?
2006 kingpin
S&S Intake
Hard Krome 3in big straights
Ness Ram bars
tfkp is offline
post #9 of 23 (permalink) Old 05-13-2013, 01:48 PM Thread Starter
Reset TPS as in bridge the pins talked about in other posts? I didn't I was able to do that on my bike since its an 06. I though that could only be done on some of the older bikes.
damage04 is offline
post #10 of 23 (permalink) Old 05-13-2013, 02:15 PM
SilentUnicorn's Avatar
How many miles on it?
m
'12 Vegas, 78 Bonneville, 69 BSA project.
SilentUnicorn is offline
